Difference in Front Axles - JeepForum.com
post #1 of 26 Old 11-27-2011, 11:52 AM Thread Starter
sf_indiana
1999 Cherokee Laredo.
Does anyone know the differences between full time and part time front axles in the 1999 Cherokee, length diameter ans so on excluding track-loc and vari-loc?
This is related to this post.
http://www.jeepforum.com/forum/f310/.../#post12569393
sf_indiana is offline
post #2 of 26 Old 11-27-2011, 11:57 AM
BigBeefy
The full time and part time refers to the transfer case. in part time the TC locks front and rear drive shafts together. In fulltime, the drive shafts are not locked together.
I am not aware of a full time and part time axle.
2004 Overland, 75k miles, 4.7L H.O.
1997 ZJ TSi, 265k miles, 4.0 I6
BigBeefy is offline
post #3 of 26 Old 11-27-2011, 12:01 PM
speedjunky1
I hope that this is the help you need. I just changed one of mine yesterday. 2000 4.7 GC Select Trac. The Vari-loc axle are about an inch longer and both are 27 spline.
speedjunky1 is offline
post #4 of 26 Old 11-27-2011, 01:15 PM Thread Starter
sf_indiana
To further explain Advance Auto lists axles for "full time" and "part time". That is where the terminology came from. There must be a difference between the select-trac (part time) and quadra- trac (full time).
Mine is full time, I have been speculating someone may have put a shorter axle in it, renderer the front differential inoperative.
It would be nice to know the difference in axles and what effect it would have putting the part time( select-trac) axle in a full time (quadra- trac) application.
I won't be able to work on it till later this week so I am exploring some possibilities.
post #5 of 26 Old 11-27-2011, 01:24 PM
mycreativename
No there is a difference between Quaddra-Trac and Quaddra Drive axles. On the QD models, there are Vari-lok axles, which as speedjunkie mentioned are about an inch longer.
I would think if the wrong axles were put in (too short of an axle) that it would just drop in the tube rather than sit in the differential.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #6 of 26 Old 11-27-2011, 04:57 PM Thread Starter
sf_indiana
How about select-trac are they shorter or longer than Quadra-trac?
post #7 of 26 Old 11-27-2011, 07:13 PM
WiCkeDuDe
WiCkeDuDe's Avatar
They are the same. Only the vari-loc axles are different length. Lets answer this a few more times.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #8 of 26 Old 11-27-2011, 07:17 PM
BreadsWJ
Smile
LMFAO!!!
---CHECK OUT MY WJ PARTS FOR SALE THREADS ---
"He who seeks knowledge, begins with humbleness" - Anon
BreadsWJ is offline
post #9 of 26 Old 11-27-2011, 10:16 PM
rockcrawlernut
Very well put!!
Once you understand the way broadly you see it in all things.
2004 WJ Special Edition 4.0L Project "
4" IRO Lift | IRO HD Track Bar | Doetsch Tech 8000 | JKS Quicker Disconnects | JKS Bar Pin Eliminators | Cooper Discoverer ST Maxx 265/75/16
rockcrawlernut is offline
post #10 of 26 Old 11-28-2011, 02:24 AM Thread Starter
sf_indiana
Without any mention of selec-trac I don't think it was answered.
Thanks for your warm welcome the the forum!
According the parts listing @ Advanced Auto there is a difference. Could it be the number of splines then?
At the bottom of this post the guy talks about getting vari-loc shafts and installing them only to strip the end off. That does not sound possible if it were too long but rather too short. There is plenty of information on this forum , but it is not all in agreement.
http://www.jeepforum.com/forum/f310/...blems-1143074/
post #11 of 26 Old 11-28-2011, 05:05 AM
FirefightinWJ
There are two axles put in WJs. A Dana 30 with an open differential and one with varilok. The varilok is only found in vehicles that have a Quadradrive system. All others have the open diffs.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
32" BFG M/Ts on JK 17's
-Devin
FirefightinWJ is offline
post #12 of 26 Old 11-28-2011, 07:46 AM
HLawton
Let me answer because I got caught with this dilemma last weekend. I'm assuming that Advance Auto uses a computer system similar to Autozone's (where I got caught). If so, then the computer or online system only gives you the choice of "part-time" or "full-time" when selecting front axle shafts (aside from drive-side or passenger-side). The problem is they don't differentiate between the two full-time systems of Quadra Trac II (open diffs) and Quadra Drive (Vari-lock).
The axle shafts for Vari-lock (listed in the computer as the "full-time" axles) are 1" longer than then axles for open diffs (listed as "part-time" axles, but also are used in the Quadra Trac II WJ's).
If you have Select Trac or Quadra Trac, then the axles sold are either the correct length or 1" too long. There is no way you could have the proper Jeep WJ CV axle shafts that are too short.
If I remember correctly, the passenger side axle shaft for a non-Vari-lock WJ is 40 1/8" long.
Edit: I also read through the link you provided. If you are referring to the last poster in that thread, I'm suspect of what he mentioned. If he tried to install Vari-lock axles in a open diff then there's no way the bearing would have bolted back on.
HLawton is offline
post #13 of 26 Old 11-28-2011, 08:04 AM
roach68
I've got a passenger side shaft at home from a Quadradrive with Vari-lok that I will measure later this evening. I bought mine from autozone.com and if I remember right they list W/Vari-loks and W/O on the website.
FOR SALE.
PAC SWI-Jack Steering wheel control interface-$35 shipped
roach68 is offline
post #14 of 26 Old 11-28-2011, 04:47 PM Thread Starter
sf_indiana
I had a chance to pull off my differential cover and found that the left axle did not turn the spider gears. I could see the end of the axle on the right side but could not see the end of the axle on the left side. This means it has broke and came out of the gear (which I doubt) or it was too short to engage the gear. It would seem there is not enough room for it to break and then side out past the remaining shaft, but I could be wrong.
It's weird, but like I said someone has had it apart before and who knows what was installed. I'll try to get the axle out before I go the the parts store, I want to know for sure what is going on.
Thanks for your help guy and for the sarcastic remarks, well I hope you enjoy looking like jerks.
post #15 of 26 Old 11-28-2011, 06:22 PM
skain8
skain8's Avatar
You need command-trac axle shafts.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
Huge price difference in front axle shafts? 99WJdan WJ Grand Cherokee Forum 9 02-06-2012 09:30 AM
Swapped front axles. Groaning noise at around 40mph Robber80 WJ Grand Cherokee Forum 1 11-21-2010 04:36 PM
Tires R .5" difference from front to back...Is this a problem for the transfer case? bassett72 WJ Grand Cherokee Forum 3 11-09-2010 12:54 PM
RVC Performance Axles Front Dana 30 wj4play WJ Grand Cherokee Forum 7 09-13-2010 06:24 PM
difference in V8 and I6 Front Springs On WJ sparkysWJ WJ Grand Cherokee Forum 3 05-31-2010 08:31 PM
