Difference between inner and outer pinion seals - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Difference between inner and outer pinion seals
Save 17.76% for the 4th of july with ruffstuff specialtiesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave on AEM Intakes from XT!
Unread 03-30-2015, 07:23 AM   #1
MichiganOutlaw
What is the difference between the inner and outer pinion seals? I have a leak on my front D30 and purchased the outer seal, but it doesn't seem like the piece I was anticipating. I was expecting a seal that I would have to pry out and tap the new one in. The one is received is just a piece of rubber.
MichiganOutlaw is offline   Reply With Quote Quick reply to this message
Unread 03-30-2015, 09:41 AM   #2
99WJ539918
Inner out outer ? Never heard of it like that. It's just a pinion seal.
99WJ539918 is offline   Reply With Quote Quick reply to this message
Unread 03-30-2015, 10:39 AM   #3
MichiganOutlaw
If you look on Crown's website it lists both an inner and an outer seal. This is why I am confused.
Unread 03-30-2015, 11:14 AM   #4
brianestep
Is it leaking from the yoke on the back of the diff, or out of one of the ends of the axle tubes?
brianestep is offline   Reply With Quote Quick reply to this message
Unread 03-30-2015, 01:21 PM   #5
MichiganOutlaw
Both, the yoke and the pass said axle tube.
Unread 03-30-2015, 05:01 PM   #6
99WJ539918
If it's leaking out of the yoke you need a pinion seal. If it's leaking it of the axle you need an axle seal.
Unread 03-30-2015, 07:09 PM   #7
MichiganOutlaw
Right, but no one has answered the difference between an inner and outer pinion seal. If you look at Crown Automotive's website, they list TWO front pinion seals, an inner and an outer.
Unread 03-31-2015, 04:54 AM   #8
99WJ539918
You'd have to call them.
