difference between Grand Cherokee,Cherokee sport - JeepForum.com
post #1 of 7 Old 05-06-2012, 07:53 PM Thread Starter
jimmyt53
what is the difference as far as framing and structure from the 2000 jeep grand Cherokee Laredo ,and 2000 Cherokee sport.
jimmyt53 is offline
post #2 of 7 Old 05-06-2012, 08:29 PM
mycreativename
They're unibodies, in other words they share nothing.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #3 of 7 Old 05-06-2012, 09:30 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
x2, the only thing they share is the fact they are both unibodies. At least, I think XJs are unibodies Either way, nothing else is shared.
~James
ezflip is offline
post #4 of 7 Old 05-06-2012, 11:27 PM
mycreativename
They are, we snapped our old XJ's, stump-pullin haha.
Jimmyt53, just curious, what exactly is it you were trying to accomplish?
post #5 of 7 Old 05-07-2012, 08:49 PM Thread Starter
jimmyt53
i was just wondering if the sport had a frame under it.i had always diven a company truck.i wanted something i could pull a trailer to the dump,and haul my hunting gear around in .was going to look at small trucks,but i wanted some thing to put my grand daughter in the back.because i was buying something 12 years old,i didnt know if the Cherokee was built a little better frame wise,as i will probably have this for a while if it dosent break the bank to own. has 144,000 on .
jimmyt53 is offline
post #6 of 7 Old 05-07-2012, 08:59 PM
mickey85
Neither has a frame per-se...the XJ is fairly light duty, but you have to remember that it has the same structure as the Comanche pickup truck, so it is technically a 1/2 ton truck with a top on it. The WJ is similar in that it is built like a truck, but was never built as a truck, if that makes sense.
It's true, you never forget your first Jeep. - 1999 Cherokee - 188,000 miles. DOA.
The Albatross - 2004 WJ Laredo 4.7, clackety lash adjusters, 3 gallons of antifreeze on the floorboard, 109,000 mile daily driver.
mickey85 is offline
post #7 of 7 Old 05-07-2012, 10:17 PM
mycreativename
If you want "just ain't gonna die reliability" the XJ's a good bet. Take care of her and she'll drive you through the apocalypse.
As long as you don't get too excessive with the weight, it will tow and haul plenty.
Cherokee or Grand Cherokee? CherokeeDrifter WJ Grand Cherokee Forum 27 05-06-2012 11:30 PM
Does 93 Cherokee 4.0 inline 6 fit a 99 Grand Cherokee? AmericanAirman WJ Grand Cherokee Forum 0 02-21-2012 09:13 AM
Reliabilty of Grand Cherokee vs. XJ Cherokee?? Wranglin4Life WJ Grand Cherokee Forum 12 01-13-2012 12:59 PM
Will a 96 grand cherokee motor work in a 2001 grand cherokee with out major issues? blacksslumina WJ Grand Cherokee Forum 4 09-01-2011 12:56 PM
Can you interchange a 2000 grand cherokee 4.7 with a newer year grand cherokee4.7? cchopp0178 WJ Grand Cherokee Forum 6 12-21-2010 11:40 PM
