Diff Swap - JeepForum.com
post #1 of 4 Old 08-11-2014, 03:23 AM Thread Starter
Deano50
2003 WJ
Wj Diff Swap
will diffs out of a 1996 grand cherokee bolt in without any modifications as i can buy whole jeep cheap with arb diff locks and other accecories
Deano50 is offline
post #2 of 4 Old 08-11-2014, 05:36 AM
WXman
Nope. Different coil spring sizes, different axle shaft lengths, etc. It would be a big job to put ZJ axles under a WJ.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #3 of 4 Old 08-11-2014, 06:15 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Youll have to be more specific. Front or rear? D30, D35, D44a? Are you planning on swapping the whole axle assembly, or just the carrier/ring and pinion? Its not going to be as easy as youre hoping.
~James
ezflip is offline
post #4 of 4 Old 09-01-2014, 08:48 PM Thread Starter
Deano50
2003 WJ
Thanks everyone i bought a 1999 wj quadra drive with limited slip diffs which i will swap over complete housings i believe that the quadra trac and quadra drive tramsmission and transfer case are the same is this correct
Deano50 is offline
