Did an offroad today, now theres a clank...HELP - JeepForum.com
post #1 of 10 Old 11-07-2010, 03:38 AM Thread Starter
blazepsi
So i did an offroad today. I was a bit hard on the jeep. I was running a bit too fast on some rocky trail(was testing the Bilsteins Damping).
When i was about to finish the trail, i noticed some strange noise coming from the front end of the jeep. I went down and inspect it. I tried to twist the steering components. Theres was no play(all tie rod and sleeves and are still new, like 2 months new). When i got home i tried to bounce the Jeep to simulate the sound thinking that it could be some loose Shocks bolts, no luck.
Im suspecting that its from the Control Arms, Bushings may need some replacement. You think? Ive been meaning to replace it anyway, after some more important upgrades.
blazepsi is offline
post #2 of 10 Old 11-07-2010, 09:36 AM
Apollo21
what does it sound like?
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #3 of 10 Old 11-07-2010, 02:39 PM Thread Starter
blazepsi
[QUOTE=Apollo21;10411694]what does it sound like?[/QUOTE
YouTube - Grand Cherokee steering linkage repair
a bit like this. @ 1:17
All steering components are ok though. Does the CA sounds like that when bushings are shut, or does it make any sound?
blazepsi is offline
post #4 of 10 Old 11-07-2010, 02:43 PM
Apollo21
TREs check em
Edit: second thought: loose drag link, loose pitman arm (would hear when turning)
SOLD
Apollo21 is offline
post #5 of 10 Old 11-07-2010, 03:36 PM Thread Starter
blazepsi
All are new and tight. Does a bad CA does this?
SOME PIC of UCA. Is it suppose to be like that, or centered.
blazepsi is offline
post #6 of 10 Old 11-07-2010, 04:42 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
The one in pic #1 looks normal. The one in pic #2 is f'd. Looks like the bushing slid out of the arm which I have never seen. Usually getting those bushings to move takes a 20-ton press.
~Richard
billzcat1 is offline
post #7 of 10 Old 11-07-2010, 07:07 PM Thread Starter
blazepsi
I guess its needs a new bushing then. Or maybe just needs to be pressed again.
blazepsi is offline
post #8 of 10 Old 11-07-2010, 07:25 PM
GraKee99
Rapist Wit
GraKee99's Avatar
While it is out, I would get a new one. And ZJ upper control arm bushings are the same as a WJ. Most auto parts stores don't seem to have WJ ones for some reason.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #9 of 10 Old 11-07-2010, 07:25 PM
billzcat1
2003 WJ
Definitely a new bushing. If it came out once, it will come out again.
~Richard
post #10 of 10 Old 11-07-2010, 07:35 PM Thread Starter
blazepsi
Thanks for the tip.
blazepsi is offline
Iceland Offroad Install - WJ 85IrocZ-28 WJ Grand Cherokee Forum 116 08-28-2017 07:56 AM
offroad lights on bumper tspalding23 WJ Grand Cherokee Forum 16 11-14-2010 11:42 PM
rustys offroad 2.5 basic kit Holland18 WJ Grand Cherokee Forum 25 09-27-2010 05:59 PM
Bad gas mileage after 90 miles offroad use lipripper WJ Grand Cherokee Forum 37 09-10-2010 03:17 PM
Blue Lake Offroad? byteHeed WJ Grand Cherokee Forum 3 08-20-2010 03:21 AM
