diagnostic codes for a Aunt - JeepForum.com
post #1 of 7 Old 07-07-2013, 10:29 AM Thread Starter
Prickett10
my Aunts Jeep is throwing three codes. p0123, p1489, and p1490. I looked the codes up saw what it said the problem is but the explanations are a little ambiguous. please help explain what I needx to do to resolve these issues for her. Thank you in advance.
Better to be mute than dispute with the ignorant.
Perversion or self exploration isn't the point in this case.In fact there will be no case, no trial by a jury of our peers just fear in the hearts of those we choose. Doing this for the knowledge of our victory, that is how we are different.
Prickett10 is offline
post #2 of 7 Old 07-07-2013, 11:05 AM
rm2001wj
rm2001wj's Avatar
P0123 means the the throttle position sensor needs to be replaced.
P1489 and P1490 indicates a problem with the radiator fan relay(s) and/or wiring. Information about the model year and engine would help here.
rm2001wj is offline
post #3 of 7 Old 07-07-2013, 11:07 AM Thread Starter
Prickett10
2004 inline 6
post #4 of 7 Old 07-07-2013, 11:10 AM
99WJ539918
First code is for the TPS. Make sure it's plugged in and there is no corrosion inside the plug. How does it idle? Any vacuum leaks?
The second codes are for the fan relay high and low side. What does your aunt drive?
*Edit - you beat me to it.
Build Thread
99WJ539918 is offline
post #5 of 7 Old 07-07-2013, 11:12 AM
99WJ539918
Originally Posted by Prickett10 View Post
2004 inline 6
2004 don't have the relay under the hood, but you have two relays in the box instead. I'd swap those with known good relays and see what happens. I'd use the starter and fuel pump relays because you would know if they don't work. Clear the codes and go for a drive. Does your aunt's car overheat, specifically at idle?
Build Thread
post #6 of 7 Old 07-07-2013, 11:19 AM Thread Starter
Prickett10
stupid question but I am not familiar with the inline 6. Where is the tps? pictures would be great.
post #7 of 7 Old 07-07-2013, 11:22 AM
narnwv
narnwv's Avatar
Throttle body. One side will have the throttle cable, on the other will be the TPS
Typing on phones sucks.
~Aaron
narnwv is offline
