Diagnosing a oscillating sound, think it's coming from the front. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Diagnosing a oscillating sound, think it's coming from the front.
Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri2007-2016 Jeep JKU 4" X-series suspension lift **dea
Unread 09-16-2013, 08:25 AM   #1
HiPERnx
Wj Diagnosing a oscillating sound, think it's coming from the front.
Hello!
I have had this sound/noise for a week or two, i have changed my rear wheel bearings, but the sound was there bore and was still there after (the sound was not the reason i changed rear wheel bearings).
The sound is oscillating, it wasn't there a month ago, and the oscillating is increasing in frequency with the speed of the vehicle. Listen to the youtube clip. You can only hear the sound at speeds above 20 mph.
Think it's coming from the front, can't find any play in the wheel bearings.
Ideas what the source of the sound can be?
HiPERnx is offline   Reply With Quote Quick reply to this message
Unread 09-16-2013, 08:31 AM   #2
rdkendrick
2003 WJ
I can hear it. It sounds like the tire wear I used to have with some bad tires. Are you sure it's not the tires? Maybe rotate just to be sure?
Sent from my iPad using my fingers
rdkendrick is offline   Reply With Quote Quick reply to this message
Unread 09-16-2013, 08:36 AM   #3
HiPERnx
Wj
The tires have 4-6 mm of thread, but can try rotating them.
The sound can best be heard in the end of the video when i go downhill.
Unread 09-16-2013, 09:49 AM   #4
spud2388
my money is on the tires as well
spud2388 is offline   Reply With Quote Quick reply to this message
Unread 09-20-2013, 06:35 AM   #5
HiPERnx
I have now rotated the tires, but the sound is still there can it be drive shaft or axle shaft ?
The sound seems to oscillate to slow to be drive shaft to me :S
Gustaf Nilstadius, www.gustafn.com
Jeep WG -99 v8, see ^ for full info
Unread 09-20-2013, 06:39 AM   #6
Jeepwagons
That is tires! If you have a spare rotate out one of the wheels at a time to isolate the offender.
2000 WJ - Trail Rig
2008 XK - Daily Driver
1979 Jeep Wagoneer - Sold 2/13
Jeepwagons is offline   Reply With Quote Quick reply to this message
Unread 09-20-2013, 07:11 AM   #7
JTS97Z28
My vote goes to tires as well. Sounds like you have monster truck tires on that thing haha. Put both front tires in back and see what happens. If it still does it then my second vote goes to a very bad front wheel hub bearing. Those are super easy to change out too.
Let us know what happens.
JTS97Z28 is offline   Reply With Quote Quick reply to this message
Unread 09-26-2013, 09:49 AM   #8
HiPERnx
Originally Posted by JTS97Z28
My vote goes to tires as well. Sounds like you have monster truck tires on that thing haha. Put both front tires in back and see what happens. If it still does it then my second vote goes to a very bad front wheel hub bearing. Those are super easy to change out too. Let us know what happens.
I swaped the wheels front to back and back to front. The sound is still conning from the front. I checked my wheel hub bearings, but there was no play at all. Can it still be the bearings ? Or can my ring an pinion be damaged ?
Unread 09-26-2013, 04:22 PM   #9
JTS97Z28
Yes it can absolutely still be bearings. Just because there is no play does not rule out a bearing. Infact, every bad wheel bearing I have dealt with had little to no play at all. I just swapped out the front wheel hub bearing on my 02 Overland and it fixed my speed related sqweek/chirp sound I had coming from the front left. New bearing was cheap, and install was a breeze.
Unread 09-26-2013, 04:27 PM   #10
nolimitssjca
Check the cable that runs past your front axle to the transfer case. It may may have pulled loose from it's mount and be rubbing. If so, mount it back (zippy tie) and see if that works.
1999 WJ 4x4, 1997 ZJ 4x4
1997 Mountaineer 4x4, 1996 Explorer 4x4
1972 Mustang Mach 1 351 Cleveland, 1972 Mustang Coupe 302
1970 Chevy C-20 350, 2002 Kawasaki Vulcan
nolimitssjca is offline   Reply With Quote Quick reply to this message
Unread 09-26-2013, 08:43 PM   #11
nickblack
Could also be your differential bearings. Does it stay the same when coasting or accelerating?
nickblack is offline   Reply With Quote Quick reply to this message
Unread 09-29-2013, 04:01 PM   #12
HiPERnx
I'll try to changed my front hubs when I got the $$ they are not so cheap in Sweden, I'm really exited for the EU-US trade alliance (cheaper jeep part for me ) .
When I change hubs i will look in the diff and se if I can se any wear on the bearings or gears
The noise is all the time, but the sound is more noticeable while coasting. But it can be just my brain. Since I don't have the engine rawr while coasting I react to the noise more.
