Debadging - JeepForum.com
post #1 of 10 Old 03-08-2013, 07:59 PM Thread Starter
ialatham4
Debadging
So I am debadging my wj and I noticed that after I got all of the glue off the jeep u can still kind of see where the letters are. How do I get rid of that or make it less obvious??
ialatham4 is offline
post #2 of 10 Old 03-08-2013, 08:45 PM
93zj40
goo gone
93zj40 is offline
post #3 of 10 Old 03-08-2013, 08:47 PM Thread Starter
ialatham4
Originally Posted by 93zj40
goo gone
That's what I've been using but it still leaves a slight outline should I just keep applying until you can't see it anymore?
post #4 of 10 Old 03-08-2013, 08:55 PM
Barricade643
You can try that, but it is possible that the paint surrounding the letters have faded just enough to always show where the letters used to be. You may also want to try a good wax to bring the color back a little.
Barricade643 is offline
post #5 of 10 Old 03-08-2013, 08:58 PM Thread Starter
ialatham4
That's what I'm starting to think it is and ok I'll try that thanks
post #6 of 10 Old 03-08-2013, 09:03 PM
Barricade643
No problem
post #7 of 10 Old 03-08-2013, 09:25 PM
lvngtheJEEPlife
Wax or buff
2001 WJ Limited 4.7 Powertech, Quadradrive, 2" BDS lift.
"If you can't get there in a Jeep, You should reconsider going there."
lvngtheJEEPlife is offline
post #8 of 10 Old 03-08-2013, 09:28 PM
Jeepers21
Try rubbing alcohol. Seems to do the trick when other things don't. Just a little on the end of a microfiber cloth should do it.
Jeepers21 is offline
post #9 of 10 Old 03-09-2013, 06:10 AM
Merc1973
Hair dryer and dental floss. That way most of the adhesive stays on the badge.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #10 of 10 Old 03-09-2013, 06:32 AM
alfaitalia
Angle grinder and a blow torch should do it!!!
Alternatively a bit of cutting compound should lose the marks!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
