Death wobble on certain braking conditions - JeepForum.com
post #1 of 22 Old 05-17-2013, 04:37 PM Thread Starter
elcorvino
2003 WJ
I don't get it. I never had DW - didn't make any modifications and out of no where, I now have death wobble upon breaking between 40 - 55 depending on the amount of pressure I put on the breaks. If I use the E-brake to assist its fine. The rotors and pads are fine. And there is only a slight vibration when driving those speeds occasionally. Any ideas at all to what would specifically cause DW as described? Again, it didn't gradually get worse - it just came out of nowhere and only occurs sometimes.
elcorvino is offline
post #2 of 22 Old 05-18-2013, 10:46 PM
fishtaconc
I would venture a guess, from what you have described, you have warped rotors. Depending on how severe they are warped, they can feel like DW. in any case, it would be a good idea to crawl under the front and look things over, looking for anything loose in the steering system.
fishtaconc is offline
post #3 of 22 Old 05-18-2013, 10:49 PM
WhiteOut
WhiteOut's Avatar
It's not death wobble, shuddering under braking is warped rotors.
WhiteOut is offline
post #4 of 22 Old 05-19-2013, 12:52 AM
ADragg
2003 WJ
Yeah, that's not death wobble. You have an 03, so your break calipers are better at preventing warpage than older models, but they still will. It's part of owning a WJ. Get some new rotors if it's bad enough.
ADragg is offline
post #5 of 22 Old 05-19-2013, 01:13 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
actual death wobble initiated by braking is usually upper control arm bushings.
ratmonkey is offline
post #6 of 22 Old 05-20-2013, 08:34 AM Thread Starter
elcorvino
2003 WJ
Yea - Was my initial assumption, but I pulled off both front tires and everything looked fine. But now logically it's the only thing that would really make much sense. Maybe something not seen by eye.
post #7 of 22 Old 05-20-2013, 08:45 AM
texlurch
Rotate the front tires to the rear and see if it helps.
You may have a bad tire.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #8 of 22 Old 05-20-2013, 09:47 AM
spud2388
Warped rotors CAN cause DW, so I wouldn't say the op doesn't have dw right yet. I know this as my bushings are pretty shot on my 99 and when my rotors begin to warp (every 18 months or so), they begin to create dw at those speeds as well. It is important the op does know the difference between dw and the regular shimmy of warped rotors. If you (the op) are sure its dw, then I would obviously change your rotors and then check your bushings up front. Changing the rotors will buy you a little bit of time but if they are causing it, soon small bumps in the road will cause it too. Its important to fix what is causing the dw, not what is initiating it... Bandaids only work for so long.
spud2388 is offline
post #9 of 22 Old 05-20-2013, 10:30 AM
WhiteOut
WhiteOut's Avatar
They can help get it going, but are never a root cause.
WhiteOut is offline
post #10 of 22 Old 05-20-2013, 06:18 PM
Prickett10
I don't mean to hijack but this threads sounds like the problem that sprung up yesterday for me. I replaced my cv shafts and during the test drive I heard a weird noise near the drivers side front tire and had pulsating in my break peddle , parked it took the tire off made sure everything was tightened down right and hit the road again. I went through a turn, applied the breaks BOOM severe side to side shaking. This wasn't a slight vibration by any means. Could I have severely warped my rotors putting everything back together? Please help me find this problem as I am driving to Texas on Friday............
Better to be mute than dispute with the ignorant.
Perversion or self exploration isn't the point in this case.In fact there will be no case, no trial by a jury of our peers just fear in the hearts of those we choose. Doing this for the knowledge of our victory, that is how we are different.
Prickett10 is offline
post #11 of 22 Old 05-20-2013, 09:29 PM
Highschool_WJ
Warped rotors, mine started after replacing brake pads and I have yet to take them off and get them turned
,,,soooo I graduated in 2013...
Highschool_WJ is offline
post #12 of 22 Old 05-21-2013, 10:16 AM
Jeepgc3
I had the same issue and the warped rotors wouldcause it to go into a dearh wobble. Yes death wobble-not shuddering. It was so bad at times i had to stop the jeep completly. Changed front rotors and pads and have not had an issue since. 182,000 miles wirh new 3" kolak lift. Never had new bushings either. Warped rotors can cause dw.
Jeepgc3 is offline
post #13 of 22 Old 05-21-2013, 10:19 AM
WhiteOut
WhiteOut's Avatar
How do brake rotors cause uncontollable oscillation of the front axle?
(Not just "They can/do")
WhiteOut is offline
post #14 of 22 Old 05-21-2013, 10:28 AM
Jeepgc3
Im telling the guy what caused and fixed mine. Sorry u dont like my story.
Jeepgc3 is offline
post #15 of 22 Old 05-21-2013, 11:06 AM Thread Starter
elcorvino
2003 WJ
It's kind of makes sense / kind of doesn't. Warped rotors if applying brakes causing fluctuation in and out... But at the same time I don't exactly see how it would cause the tires to wobble so dramatically.
Either way - I'm meeting with TJSWJ in about 3 weeks for a new front axle. I'll just bolt new pads / rotors on and with a new everything I should hopefully be good.
