Dead Jeep - JeepForum.com
post #1 of 12 Old 12-17-2012, 05:27 PM Thread Starter
WheelinCowboy
1989 XJ Cherokee
Wj Dead Jeep
So about a month or so ago i posted about some motor issues I had. Well it turns out that i need to have the valve seat rebuilt. Mechanic wants $2000 to pull it apart and take it to a machine shop. With a wedding, honeymoon, and having to find a new place to live in the next few months I DO NOT have that kind of money to throw into this thing.
I'm considering taking the motor apart myself and taking it to a machine shop that will do it for $100. I've never done this before and am hoping that I don't have to pull the motor. I've been looking around on the forum but haven;t found it yet. I'm looking to see if anyone has posted a thorough motor teardown with pictures.
any help is always appreciated. Thanks all
1989 Cherokee (XJ) I6 4DR 4X4 Stock... for now
2002 Grand Cherokee Overland- Blown Motor *SOLD*
WheelinCowboy is offline
post #2 of 12 Old 12-17-2012, 05:59 PM
Ravie
I6 or V8? I'm guessing V8 since those have valve seat issues...
1999 WJ - Over 10k on the 4.0 rebuild. FB/BDS 2" lift (2.5") w/Bilstein 5125's. General Class Ham...KC0LUA
Burlbook48 sez "Nothing moves a project along faster than cubic dollars." Certified Thread Killer.
Ravie is offline
post #3 of 12 Old 12-17-2012, 07:21 PM
99SK04GTX
http://www.amazon.com/Cherokee-1993-...herokee+manual
If you are going to take on a job like that with the skills you have, spend a little on a repair manual.
99SK04GTX is offline
post #4 of 12 Old 12-18-2012, 12:47 AM
alfaitalia
Or just download the factory one in PDF form for free off the net!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #5 of 12 Old 12-19-2012, 09:00 AM Thread Starter
WheelinCowboy
1989 XJ Cherokee
Wj
It is the V8 4.7 HO in the Overland
post #6 of 12 Old 12-19-2012, 09:01 AM Thread Starter
WheelinCowboy
1989 XJ Cherokee
Wj
Thanks. I have the dealer repair manual. do you know if it is absolutely necessary to pull the engine or can i get away with leaving it in the car?
post #7 of 12 Old 12-19-2012, 09:16 AM
Cirruslydakota
Pull the heads first, then see what shape your pistons and cylinder walls are in. If theyre messed up then its time to pull the short block too.
Sent from inside my 4.0.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #8 of 12 Old 12-19-2012, 09:19 AM Thread Starter
WheelinCowboy
1989 XJ Cherokee
ok thanks. THe shop i took it to pulled the heads and said the only issue was the valve seat. so i'll get to work on it myself over my xmas vacation hopefully and see for myself
post #9 of 12 Old 12-19-2012, 10:44 AM
Cirruslydakota
In that case just get the heads reworked and clean the block deck and you'll be good to go. Get a FSM if you don't have one already, its a valuable resource.
Bear - 99 WJ Laredo
post #10 of 12 Old 12-19-2012, 11:42 AM
Breadfan
Wait, you said the shop pulled the heads and determined it was valve seat - they were 90% done if they pulled the head and put it back! If it was just a valve issue, the hardest part is the teardown to get the heads off IMO. I hope they didn't quote $2000 after doing all that, b/c really they did most of the work minus the send to machine shop part.
But yes, you can certainly do this without pulling the motor as indicated above. Searching for Headgasket threads should give you what you need. I've been outlining some of my experiences with that job in this recent thread: http://www.jeepforum.com/forum/f310/...haust-1450874/
You may not be doing a headgasket specifically, but for pulling a head the discussion is probably similar.
Breadfan is offline
post #11 of 12 Old 11-08-2013, 05:25 PM Thread Starter
WheelinCowboy
1989 XJ Cherokee
So I had the head remachined and put back together by a friend back in April. 5 days later it blew up. Hole in the valve cover. finally got the money together to have it towed and looked at by a mechanic. the block sucked a valve in and now the whole motor needs to be replaced. Block is shot.
I'm looking into a warranty from the shop that my friend went to to remachine the head but i'm not too hopeful. My mechanic is looking around to find a used motor. He said he is going to try and get it down around $2K. any ideas or leads on a 4.7 HO V8 would be helpful. I plan on selling this thing as soon as it is paid off so as cheap as possible.
post #12 of 12 Old 12-03-2013, 01:07 PM Thread Starter
WheelinCowboy
1989 XJ Cherokee
Sold it. It's going to go live in Mexico now
