Daystar coil spacer installation on 2001 WJ - JeepForum.com
post #1 of 3 Old 02-03-2009, 12:45 PM Thread Starter
lapinski89
Hey I was looking into getting a 2" coil spacer kit for my 2001 Grand Cherokee for a little more height and was just wondering how difficult they are to install. Thanks
lapinski89 is offline
post #2 of 3 Old 02-03-2009, 01:33 PM
vosevichs
Not hard at all. They send pretty good instructions.
http://www.fatbobsgarage.com/instructions/64200C.pdf
You'll need a spring compressor for the RF spring. Jack up under the axle. Put jack stands under the frame. Remove tires, Lower on to stands, disconnect shocks and sway bar, lower axle. Remove LF spring, remove isolater. Install spacer, then isolater, then spring. I had to stand on axle to get everything to go in. On the RF you'll need a spring compressor to get that spring back in. Make sure you get the pigtail of the spring in its pocket. They'll turn by hand with the axle hanging. Jack back up, install shocks, and reattach sway bar. The rear is the same but you'll won't need a compressor. On the rear axle shock mount remove the bolt as the nut is attached to the bracket. Some companys suggest you put the rear spacers on the axle, others say on top of the spring. But everybody here says to put them on top of the springs. I did.
Scott Vosevich
vosevichs is offline
post #3 of 3 Old 02-03-2009, 02:27 PM Thread Starter
lapinski89
Thanks a lot Scott
wj 3/4in coil spacer g-off70 ZJ Grand Cherokee Forum 4 08-02-2009 06:40 PM
2 inch spacer installation DEUJEEP ZJ Grand Cherokee Forum 3 06-12-2009 07:54 PM
Installation of a 2" spacer kit lapinski89 ZJ Grand Cherokee Forum 5 02-03-2009 05:59 PM
Coil spacer installation question hike4it ZJ Grand Cherokee Forum 11 01-28-2009 10:56 PM
Daystar Coil Spacers JeepStangGuy ZJ Grand Cherokee Forum 2 10-13-2002 09:00 PM
