Dana 44 rear axle seals - JeepForum.com
post #1 of 9 Old 04-04-2011, 07:26 PM Thread Starter
forttis
Hello everyone,
Just a bit confused with this job. I got a 2000 WJ with Dana 44 and a leaking driver side rear axle seal. I have the fluids and seals. Where are the seals located? I've read pages/threads where the seals are located right inside the diff. I've also read others where they are behind the bearing on the axle shaft which is pressed in there.
Which one is right or which one do i have? I was hoping on doing it myself as i'm rebuilding my trac-loc clutches as well.
Thanks in advance!
forttis is offline
post #2 of 9 Old 04-04-2011, 07:35 PM
gatorayde
Behind the wheel bearing on the axle shaft
gatorayde is offline
post #3 of 9 Old 04-04-2011, 07:47 PM Thread Starter
forttis
Are Dana 44's different from front and rear, will this be a front axle? http://www.pavementsucks.com/tech-article-3.html or how come the one from the link is different?
forttis is offline
post #4 of 9 Old 04-04-2011, 07:53 PM
gatorayde
Yes they are, and thats an iron 44. You have a d44a (aluminum). WJ D35 and D44a seal/bearing replacement is the same (and I believe same parts)
post #5 of 9 Old 04-04-2011, 07:56 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Your front axle is a Dana 30, not a 44. The seals for the front dana 30 are inside the pumpkin housing. They are on each side of the carrier which has to be pulled out to change the seals out.
On the rear Dana 35 and Dana 44 they are on the axleshaft between the axle flange and wheel bearing.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #6 of 9 Old 04-04-2011, 08:08 PM Thread Starter
forttis
I was hoping it would have been the same as replacing the D30's but at least is all clear now!
Can it be bad to keep toping it up until i get some warmer temps and get to it?
forttis is offline
post #7 of 9 Old 04-04-2011, 08:21 PM
gatorayde
I'd say its easier than a D30 because you dont have to pull the cover off and take the carrier out. If its just a slight leak you wont even notice a change in diff fluid level.
post #8 of 9 Old 04-04-2011, 08:23 PM
WiCkeDuDe
WiCkeDuDe's Avatar
No no no. Changing the 44a seal is much better than the front. All you need to do is take out the axleshaft, crack off the bearing, remove the seal, press on new stuff and reinsert. Dont even need to remove the fluid or cover. Might need a slidehammer to pull the shaft though.
post #9 of 9 Old 04-04-2011, 08:39 PM Thread Starter
forttis
Only problen is i have no access to a press otherwise i agree that it is easier. With that in mind i might try to get a shop to press it, doing the rest of the work myself.
I will have to get the diff cover off anyway as I am putting in new clutches for the Trac-loc and new spider gears. I'd like to get it all done at once with out wasting too much fluid and time.
Thanks a lot for all the help and quick responses!
forttis is offline
Rear Axle Seals leaking.... Okiesteve WJ Grand Cherokee Forum 2 03-01-2011 05:15 PM
Rear Axle Seals CBlakeNS WJ Grand Cherokee Forum 9 02-03-2011 12:01 AM
Rear axle seals Dragon158 WJ Grand Cherokee Forum 3 01-10-2011 03:53 PM
Dana 30 front axle seals jtsjeep99 WJ Grand Cherokee Forum 13 07-17-2010 07:53 PM
replacing rear axle seals help metalhead WJ Grand Cherokee Forum 6 03-14-2010 07:59 PM
