Dana 30 JJ upgrade - JeepForum.com
post #1 of 37 Old 11-07-2013, 07:05 PM Thread Starter
MuddyWJ
Dana 30 JJ upgrade
Been looking for a way to quit replacing my upper ca bushing and came across this.
http://www.currieenterprises.com/ces...t.aspx?id=2889
It just doesn't say it's for a WJ or ZJ for that matter. Will it still work?
MuddyWJ is offline
post #2 of 37 Old 11-08-2013, 02:37 AM
c_ema
2003 WJ
Interesting.............
WJ Grand Cherokee 2.7 CRD Overland MY'03, OME HD springs, King 2.5 SHOCK, Addco rear sway bar, JKS® Adjustable Trackbars, JKS® Adjustable Front Lower Control Arms, JKS® HD Tie Rod, OPTIMA® RedTop®, j4e TCase Skid Plate,Tires Pirelli Scorpion ATR 235/65 R17, Radio USA SPEC Ipod interface
c_ema is online now
post #3 of 37 Old 11-08-2013, 02:39 AM
afusco1222
I would measure the OD of your current bushing and see if it's in spec with this JJ replacement but if I were to guess, I would say that it is a match.
afusco1222 is offline
post #4 of 37 Old 11-08-2013, 05:58 AM
skain8
skain8's Avatar
This should help a bit. Don't have this axle anymore, but from what I wrote, the linked flex joint you posted was a direct fit for the housing joint. The tube side joint is also fairly easy, and an upgrade worth considering to have 2 flex joints instead of a mix-match. I apologize in advance for the obscene sized photos...
http://www.jeepforum.com/forum/f310/...stall-1090683/
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #5 of 37 Old 11-08-2013, 07:13 AM
3JsWJ
I have been looking into this also. The part that I don't understand is why you can't use the currie JJ on both sides? If you replace the bushings, they are always the same part so why wouldn't the JJ be the same on both sides?
04 WJ-4.7, 242HD, JK D44, JK HP30, 4" IRO, LSR Bumper, Warn M8000, 33" MTZ
03 WJ-SOLD
3JsWJ is offline
post #6 of 37 Old 11-08-2013, 09:03 AM
skain8
skain8's Avatar
No dice. The width of the stock tube bracket is too narrow for the Currie flex joint to be pressed into.
skain8 is offline
post #7 of 37 Old 11-08-2013, 09:09 AM Thread Starter
MuddyWJ
I have IRO LAs so I'll only need one. My lowers have bushings as well and thought about replacing with JJs once they need it, but was worried about noise and such associated.
MuddyWJ is offline
post #8 of 37 Old 11-08-2013, 09:22 AM Thread Starter
MuddyWJ
No dice. The stock tube-side bracket is too narrow and the Currie joint will not press into it.
So I'll be good since I have IRO LAs.
MuddyWJ is offline
post #9 of 37 Old 11-08-2013, 07:16 PM
PhantomWJ
2003 WJ
I thought someone on hete was able tonpress these in. currie ce-9112m...just had to drilll a bigger hole on the arm to fit the bigger bolt.
PhantomWJ is offline
post #10 of 37 Old 11-23-2013, 09:26 PM Thread Starter
MuddyWJ
I ordered the JJ last night. I'll post up pics and effects after it's installed.
MuddyWJ is offline
post #11 of 37 Old 11-23-2013, 09:29 PM
PhantomWJ
2003 WJ
Ive had mine for months...one of these days ill put them in.
post #12 of 37 Old 11-24-2013, 09:05 AM Thread Starter
MuddyWJ
I'm in a pickle I looked under their and my bushing is completely torn in the middle. No wonder I was feeling a little shimmy. Hope currie is fast with shipping.
MuddyWJ is offline
post #13 of 37 Old 11-24-2013, 02:58 PM
StrokedWJ
StrokedWJ's Avatar
I've run the 1/2" bolt version for the axle upper side of my 3 link for a couple of years now. I like it much better than the bushings.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #14 of 37 Old 11-24-2013, 03:42 PM Thread Starter
MuddyWJ
Anybody run them on the body side of LAs?
MuddyWJ is offline
post #15 of 37 Old 11-24-2013, 05:10 PM
StrokedWJ
StrokedWJ's Avatar
I've worked them into every joint in my suspension as the rubber bushings have needed replacing.
I've got a mix of Curry Johnny joints, Trail Gear Creeper joints, Rubicon Express flex joints, and Ballistic Fab flex joints. I like joints with the threaded side adjusters better. You can adjust preloaded and they're easier to take apart come time for a rebuild. I'm planning to pick up some of the new Barnes4wd flex joints next the I need some. He's local to me and I've heard nothing but good things about them.
