-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   Dana 30 JJ upgrade (http://www.jeepforum.com/forum/f310/dana-30-jj-upgrade-1769362/)
MuddyWJ 11-07-2013 07:05 PM
Dana 30 JJ upgrade
Been looking for a way to quit replacing my upper ca bushing and came across this.
http://www.currieenterprises.com/ces...t.aspx?id=2889
It just doesn't say it's for a WJ or ZJ for that matter. Will it still work?
c_ema 11-08-2013 02:37 AM
Interesting.............
afusco1222 11-08-2013 02:39 AM
I would measure the OD of your current bushing and see if it's in spec with this JJ replacement but if I were to guess, I would say that it is a match.
skain8 11-08-2013 05:58 AM
219 Attachment(s)
This should help a bit. Don't have this axle anymore, but from what I wrote, the linked flex joint you posted was a direct fit for the housing joint. The tube side joint is also fairly easy, and an upgrade worth considering to have 2 flex joints instead of a mix-match. I apologize in advance for the obscene sized photos...
http://www.jeepforum.com/forum/f310/...stall-1090683/
3JsWJ 11-08-2013 07:13 AM
I have been looking into this also. The part that I don't understand is why you can't use the currie JJ on both sides? If you replace the bushings, they are always the same part so why wouldn't the JJ be the same on both sides?
skain8 11-08-2013 09:03 AM
219 Attachment(s)
No dice. The width of the stock tube bracket is too narrow for the Currie flex joint to be pressed into.
MuddyWJ 11-08-2013 09:09 AM
I have IRO LAs so I'll only need one. My lowers have bushings as well and thought about replacing with JJs once they need it, but was worried about noise and such associated.
MuddyWJ 11-08-2013 09:22 AM
Originally Posted by skain8 (Post 17542201)
No dice. The stock tube-side bracket is too narrow and the Currie joint will not press into it.
So I'll be good since I have IRO LAs.
PhantomWJ 11-08-2013 07:16 PM
I thought someone on hete was able tonpress these in. currie ce-9112m...just had to drilll a bigger hole on the arm to fit the bigger bolt.
MuddyWJ 11-23-2013 09:26 PM
I ordered the JJ last night. I'll post up pics and effects after it's installed.
PhantomWJ 11-23-2013 09:29 PM
Ive had mine for months...one of these days ill put them in.
MuddyWJ 11-24-2013 09:05 AM
I'm in a pickle I looked under their and my bushing is completely torn in the middle. No wonder I was feeling a little shimmy. Hope currie is fast with shipping.
StrokedWJ 11-24-2013 02:58 PM
I've run the 1/2" bolt version for the axle upper side of my 3 link for a couple of years now. I like it much better than the bushings.
MuddyWJ 11-24-2013 03:42 PM
Anybody run them on the body side of LAs?
StrokedWJ 11-24-2013 05:10 PM
I've worked them into every joint in my suspension as the rubber bushings have needed replacing.
I've got a mix of Curry Johnny joints, Trail Gear Creeper joints, Rubicon Express flex joints, and Ballistic Fab flex joints. I like joints with the threaded side adjusters better. You can adjust preloaded and they're easier to take apart come time for a rebuild. I'm planning to pick up some of the new Barnes4wd flex joints next the I need some. He's local to me and I've heard nothing but good things about them.
The time now is 09:50 AM.
