D44a Truss, anyone make them now? - JeepForum.com
post #1 of 40 Old 03-14-2013, 06:46 PM Thread Starter
STORM_JK
Been searching around and was going to get the MVC one but then noticed they went out of business.. TNT is another but cannot find pictures of this (anyone have it?). Going to be adding a locker (spartan still available?) and would like the extra strength for it to hold up. Would rather buy then get one built
'13 JK 6-spd | 3.5" RK | 35" MTR/K | Lots Of Welding
STORM_JK is offline
post #2 of 40 Old 03-15-2013, 12:05 AM
texlurch
TNT makes one for the standard D44, and it goes on top.
Another company had posted some with a skid but I don't know if those ever made it into production
here is the thread on mallcrawlin about it: http://mallcrawlin.com/forum/showthr...a-WJ-D44A-axle
I bought a TNT D44 and am trimming it and adding a skid for the yoke. Looks like it will work perfect.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #3 of 40 Old 03-15-2013, 04:48 PM Thread Starter
STORM_JK
Ill take a look at that thanks. The d44a and hd models are the same right?
STORM_JK is offline
post #4 of 40 Old 03-16-2013, 12:17 AM
texlurch
Yep, 44A and HD same. Standard D44 a little different shape to the center chunk.
Also, the TNT truss is designed to go on top of the D44, so using it underneath requires some "fitting"
texlurch is offline
post #5 of 40 Old 03-16-2013, 07:55 AM
TJSWJ
Dana 44a and 44hd are the same when talking Chrysler differentials. Ford has a Dana 44hd as well, but its a front diff.
TJSWJ is offline
post #6 of 40 Old 03-16-2013, 08:04 AM
USFORCES
mvcustoms made one for under but I don't know if there still in business, it still had to be welded on. Best bet is fab your own over the top...
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
post #7 of 40 Old 03-16-2013, 08:44 AM
texlurch
I put mine under to make it easier to attach the front skid to.
Not to mention clearing the UCA mount, altho you could attach it to that.
texlurch is offline
post #8 of 40 Old 03-16-2013, 10:31 AM Thread Starter
STORM_JK
Ya mvc either went out of business or their site is down.. the plan is to make it go underneath for ease of a skid and not dealing with the uca mount. Not too worried about ground clearance it would mostly be for strength. Guess I'll go buy some plate and start fitting it, just gotta get someone to weld it all together, kind of the same way mvc had theirs made up. 3/16 should be strong enough to hold up. Time to bust out the tape measurer
STORM_JK is offline
post #9 of 40 Old 03-16-2013, 11:32 AM
texlurch
The TNT one is 3/16. Once I trimmed it out to fit the 44A cover side, the other cut is almost perfect on the front edge, maybe 1/4 in clearance on the housing. It hangs about 1/2 inch below the housing flange right now but I still need to do just a little more fitting to get it "just" right.
It is just above 1/2 up the sides of the axle tubes, and reaches the sway bar mounts on either side.
I am still out of town for a couple more weeks but I'll post up pics when it gets welded on.
texlurch is offline
post #10 of 40 Old 03-16-2013, 01:42 PM Thread Starter
STORM_JK
Yea please post pics once its all said and done, theres no rush on doing this since its still pretty cold up here. But I'd like to have it ready for the summer.
Only lockers available for it are aussie and spartan right?
STORM_JK is offline
post #11 of 40 Old 03-16-2013, 11:35 PM
texlurch
yep
texlurch is offline
post #12 of 40 Old 03-18-2013, 11:27 AM
berndog67
2003 WJ
been looking for one for awhile and decided to fab up my own based on that TNT one, but im thinking of a way to keep it low profile and run along the top of the diff, almost like an a arm spacer and truss all in one, so it will hopefully make the entire axle stronger, not just keep the axles inline, what do u guys think
2003 WJ Overland, 4.7HO, D30 & D44A (1 tons going in now!), RC Long Arm, lifted 4" Front 6" Rear, RC 2.2 4" Shocks, JKS track bar, custom hi-steer, 35" Procomp M/T's on JK rims, beefed up Overland rock rails, custom skids and dif gaurds, Rugged Ridge 8500 synthetic winch in custom hidden mount
berndog67 is offline
post #13 of 40 Old 03-18-2013, 11:41 AM
TJSWJ
like this http://s159.photobucket.com/user/qua...%20skid?page=1 you should follow that thread on mallcrawlin
TJSWJ is offline
post #14 of 40 Old 03-18-2013, 12:15 PM
berndog67
2003 WJ
dam i guess i might have to join that forum too, within 5 mins i found like a half dozen ideas i havent seen on here, course there truss design seems alittle over done, im thinking more like a simple 1/2 plate t beam setup with the top of the t beam running over the diff, that way it isnt so big and complex, alot less welding too! but i might end up buying one if the price stays the same, because it would mean less down time for me
post #15 of 40 Old 03-18-2013, 12:35 PM Thread Starter
STORM_JK
I really like that idea. Been following the mall crawling thread but did they ever go into production?
STORM_JK is offline
