D44 Rear Axle L and R Specific?! - JeepForum.com
post #1 of 3 Old 06-10-2014, 08:40 AM Thread Starter
JMZ101586
Are the left and right axles side specific? I dont visually see a difference between the two unless I'm missing something? I DO NOT have QuadraDrive, I have Quadra Trac.
Basically Ive done the rear axle seals and bearings on my D44 reinstalled and been driving for a bit and I noticed the one side is leaking slowly again. I have no driveability issues but like a dumb *** when I did it I DID NOT mark the L and R axle and did not do them one at a time so they COULD of been swapped. Is it physically possible to screw them up and install them in the wrong position?
JMZ101586 is offline
post #2 of 3 Old 06-10-2014, 11:05 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The left axle shaft is 1" longer.
Left axle shaft = 31.34", right axle shaft = 30.34".
Edit: The above #s are for an open diff or Trac Lok diff. If you have Vari Lok, the left axle shaft is 3" longer.
Wheelin98TJ is offline
post #3 of 3 Old 06-10-2014, 11:34 AM Thread Starter
JMZ101586
So is it physically impossible to install them wrong and drive over 1000 miles without the rear blowing up or throwing an axle!?
