D35-->D44a axle swap - JeepForum.com
post #1 of 68 Old 08-04-2007, 10:30 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
So I was looking to add a rear locker and I wasn't plan on locking my D35 so I decided to build up a D44a. I had one shipped down from Washington, threw in an aussie locker & all new brake lines, and finally Kolak's brake upgrade.
I picked the D44a to maintain my ABS/Speedometer sensors & because it is 100% bolt up...
Start with one Jeep and one D35 axle
Add a dash of D44a:
Time to remove the shocks:
Uh oh, I twisted off the bolt heads...out with the grinder for both axle side shock bolts:
The nut WAS welded on...that is the part that needs to be grinded off:
Next I disconnected the e-brake. This is done inside, under the seat and under the carpet. There is a cut out for it. Lift the carpet and for each brake cable coming into the cab, there are three tabs holding it in there. Push the three tabs in and it'll pop out:
In the above pic, I also disconnected the ABS lines (2 x 10mm bolts, 1 per side), and disconnected the brake line. It LEAKS everywhere, it drains from the reservoir so you'll need to stop it. I grabbed my oil absorbant material from my trail repair kit and it absorbed the brake fluid great:
Next I tried to vicegrip some tubing over it, but it still leaked since I didn't have big enough vicegrips.
...So I added some RTV sealant to the end and it sealed up as soon as a little pressure built up in the line. Great, no more leak.
After this brutal Mag-Chloride filled winter, I had lots of rusted bolts so I cleaned them all up, then taped off the threads and painted them all:
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #2 of 68 Old 08-04-2007, 10:30 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
I removed the driveshaft, and finally I removed the A-arm and LCA's...Then I pulled out the axle:
This axle is just begging to go in now
It belongs here:
So Up it goes, LCA's and A-arm attached:
Time to install the springs. CRAP, my Teraflex 4" spring may have an issue...look at the small piece I found on the old axle:
Shocks and swaybar on next:
Then the ABS, E-brakes, and brake line.
Tada, now who can figure out what I didn't reconnect at the very end?
post #3 of 68 Old 08-04-2007, 10:39 PM
10achik
I ate what?
10achik's Avatar
Just a tip for the future, you can stick a golf tee in the end of the brake line to keep it from leaking...that's what i did.
Looks great!
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #4 of 68 Old 08-04-2007, 10:45 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
I don't golf Good idea though
post #5 of 68 Old 08-04-2007, 10:47 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
So I had this "thought" months ago. I wonder if my drive shaft will be the wrong size.
I kept putting it off, "ignoring" the "problem"
Well, it is 2" too long
So I could either:
1) Have a local shop modify my drive shaft to be shorter, easy to cut and reweld. This is the cheapest.
2) Have a local shop or Tom Woods build me a new drive shaft that is beefier.
3) Get Tom Woods SYE for the 242 with a new beefier shaft, most expensive @ $500 ($900 - $400 core deposit)...
I am leaning towards option 3 so I could drive off the trail w/o a rear shaft...
I need to see if Teraflex will warranty my springs since they are only 16 months old, I doubt it. If they don't, I'll order a 1" taller spring since my back sits a little low right now, especially with the gear I haul around.
I need to get my Jeep to the dealership to bleed the ABS system. I "hear" that if you get air in the ABS system they need to cycle the abs valves to get air out of them. Right now the brakes "work" but are moderately soft
post #6 of 68 Old 08-04-2007, 11:01 PM
10achik
I ate what?
10achik's Avatar
I didn't have any problems with the ABS, but it took a few times of bleeding the brakes to get more firm again. Use clear tubing so you can see when all the air comes out.
Ken
2006 Pontiac G6 GTP
10achik is offline
post #7 of 68 Old 08-05-2007, 10:03 AM
JCDubya
2009 WK
What does the "Kolak brake upgrade" consist of?
JCDubya is offline
post #8 of 68 Old 08-05-2007, 10:05 AM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Expensive pads & rotors
post #9 of 68 Old 08-05-2007, 10:21 AM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
WOW Bling Bling brakes.
2013 FR-S
BlaineWasHere is offline
post #10 of 68 Old 08-05-2007, 01:31 PM
JLH
This is a great write-up! This is the same thing I had planned to do. As far as the driveshaft goes, have you thought about picking up a stock one from a salvage yard? What I mean is one for a GC with 4.7L and Select-track. The pinion neck on the D44a is longer than the D35, thus your driveshaft is too long. Yeah that's what she said
Keep us informed of your progress.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
JLH is offline
post #11 of 68 Old 08-05-2007, 02:57 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Nice Ryan! as I was reading I figured you were referring to your drive shaft.
I would just get your old DS cut and re-tubed. You have the 242 correct? I am fairly certain that your tail shaft is sealed anyway, you should not have any fluid leakage. Your tail shaft looks like this correct?
If yours is that style (I was under the impression that all WJ were) you will be fine.
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #12 of 68 Old 08-05-2007, 04:24 PM
Cebby
Great Writeup!!
2000 WJ Laredo 4.0 4x4 Taupe Frost - Stroker | Clayton LA w/3" Lift | 33's on JK 17's | Axles next
Cebby is offline
post #13 of 68 Old 08-05-2007, 05:54 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Yeah Tim it is like that, hmm, so no leaking? Cool! I'll try it out tonight.
post #14 of 68 Old 08-05-2007, 06:13 PM
Silverstonev8
I have that tom woods sye in mine. its a nice setup but as stated above your stock setup wont leak without a shaft installed.
I had the problem with my rear teraflex springs sagging in the from the day I got them so I returned the rears, kept the fronts. I ended up putting IRO 5.5"rears in with a 3/4 kevins spacer in there and its on the money even at all 4 corners now.(thats with a 33" spare tire and some gear in the back...)
02 WJ, 4.0, 242, 4.56s
Silverstonev8 is offline
post #15 of 68 Old 08-05-2007, 06:21 PM
Silverstonev8
O yea. I forgot to ask what you're going to do with the 35. I plan on breaking some axles now that I have the 33s and 4.56s. Would you be willing to sell me just the shafts?
Swap D35 with D44a WhiteOut ZJ Grand Cherokee Forum 16 03-10-2010 10:34 PM
D44a swap ? bigjeep6303 ZJ Grand Cherokee Forum 5 12-19-2009 01:16 AM
Axle loud axle whine from D44a jopolly3 ZJ Grand Cherokee Forum 21 04-24-2009 11:51 AM
d44a axle swap bigbluezj94 ZJ Grand Cherokee Forum 3 01-25-2009 04:34 PM
WJ D44a axle into a 97 ZJ drespecki ZJ Grand Cherokee Forum 11 05-23-2008 09:19 PM
