D30 99 WJ GC Limited axle help - JeepForum.com
post #1 of 2 Old 09-28-2010, 12:43 PM Thread Starter
skiebuster
my worm gears and metal shaft in from axle are shot.
mine is a 3:73 gear set and wanting to know from what axles can i look through at the boneyards will fit?
I can order the spider gears and new pin plus shims for 95 bucks. But would be easier i think to install a different front assembly.
skiebuster is offline
post #2 of 2 Old 10-01-2010, 09:39 AM Thread Starter
skiebuster
Wj
read on here that the 96 up D30 axles all use the same carrier etc due to the TJ design in use on the D30.
anyone know this to be fact?
Looking for a used carrier to replace mine that has the worn parts..
99? limited? branscorp WJ Grand Cherokee Forum 3 09-11-2010 11:15 AM
99 WJ Limited front axle skiebuster WJ Grand Cherokee Forum 2 07-29-2010 01:46 PM
limited grille jakellahan WJ Grand Cherokee Forum 6 03-16-2010 11:17 PM
99 GC limited towing ??? mike481 WJ Grand Cherokee Forum 4 08-03-2007 11:22 PM
Need advice on 01 limited v8 srad711 WJ Grand Cherokee Forum 2 12-03-2003 07:28 PM
