CV Joint replacement - JeepForum.com
post #1 of 37 Old 06-29-2011, 07:28 PM Thread Starter
srode
2008 XK Commander
Doing some brake work on our 99 Jeep Grand getting it ready to sell - found a CV joint boot torn PS - anyone replace one of these? How hard, how long, any special tools I need. May just take it somewhere but will do it myself if it's not too involved.
2008 XK Commander Limited 4.7 Quadra Trak II
1999 Jeep Grand Cherokee 4x4 Quadra Drive 4.7 L 163,000 miles(sold)
2004 GMC SLT Crew Cab 4x4 Duramax Diesel
1969 Camaro Pace Car
1969 Camaro Hard top
91 Cherokee - sold at 188,000 miles, still runing great at 250k last report
srode is offline
post #2 of 37 Old 06-29-2011, 07:36 PM
biggoofy
Your local parts store will have everything you need its not very hard.
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #3 of 37 Old 06-29-2011, 07:53 PM Thread Starter
srode
2008 XK Commander
Do I need to pull the hub and axle or are you talking about a split boot and gluing?
srode is offline
post #4 of 37 Old 06-29-2011, 08:26 PM
biggoofy
you will have to pull it all apart
Zack
13 JKU Stock
biggoofy is offline
post #5 of 37 Old 06-29-2011, 09:14 PM
sskilla
yep. the hardest part will be loosening the axle nut. grab your cheater bar
'95 ZJ: 5.2 v8 / 231 Tcase / 46RH
sskilla is offline
post #6 of 37 Old 06-29-2011, 09:17 PM
-HH-Racer
I just replaced the boot on mine, and cleaned out the joints, umm yeah use the cheater bar, easiest way. And make sure you have a "banding tool". Not having that tool really screwed me over
-HH-Racer is offline
post #7 of 37 Old 06-29-2011, 09:20 PM
davigzj
U can see it on you tube under zj axel or ch axel ..good luck gona do mine soon..
davigzj is offline
post #8 of 37 Old 06-30-2011, 05:00 AM
roach68
Very good write up on removing the front shafts.
http://www.jeepforum.com/forum/f310/...w-pics-377208/
FOR SALE.
PAC SWI-Jack Steering wheel control interface-$35 shipped
roach68 is offline
post #9 of 37 Old 06-30-2011, 04:55 PM Thread Starter
srode
2008 XK Commander
Thanks guys, I bought the whole shaft and coupler (rebuilt) for $59 already assembled - It's about 3 feet long most it being the shaft going into the axel housing from the coupler, does that sound right? I was expecting a shorter shaft to mate with another shaft in the housing for some reason - this is a 99 with the Quadra Drive progressive coupler in the front.
Never mind, I read the link on installation - it looks like the shaft in that set of instructions so I guess its right. Only bummer is I have the calipers and rotors off alreay for the brake work so I have to reassemble probably to brake the axle nut loose - no biggy - looks like a simple job.
fortunately for me (in a wierd way) I just replaced the hub and bearing on my 3/4 GMC truck, and have all the tools to do the job already including torque wrench that goes over 175, 36mm socket, and a LOOOONNNNGGG Breaker bar. There were bolts on it I had to torque to 220 ftlbs.
srode is offline
post #10 of 37 Old 06-30-2011, 06:54 PM
xJoshxx
2012 WK
does not have a progressive coupler. you have limited slip differentials with the quadra drive. you need to make sure they gave you quadra drive shafts they are shorter than the select-trac axles.
BE sure you have 12 point 13mm socket.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #11 of 37 Old 06-30-2011, 07:56 PM Thread Starter
srode
2008 XK Commander
Quadra Drive has the gearator pump that engages more as the difference between the speed of the tires increases. That's not a limited slip is it? I thought that was a progressive coupler (jeep calls it a varilock differential)? My understanding is limited slip engages more as the the temperature of the gear oil increases - caused by friction of the clutches against the spider gears caused by speed difference? Am I wrong? Selectrac is completely open differentials with no clutches I thought. Quadra Drive II has an Elocker with clutches instead of the progressive coupler I thought, they do call it a limited slip I believe with an elocker ?
If I'm wrong, I got the wrong shaft. let me know what you think - is a progressive coupler not a varilock differential?
srode is offline
post #12 of 37 Old 06-30-2011, 08:24 PM
narnwv
narnwv's Avatar
you're combining definitions.
progressive coupler= the clutch pack assembly in the transfer case
vari-lock= the clutch pack limited slip mechanism in the differential
~Aaron
narnwv is offline
post #13 of 37 Old 06-30-2011, 08:28 PM Thread Starter
srode
2008 XK Commander
This is where I read the terms - here they mention progressive diff with the term Varilok for the Quadra Drive system.
http://www.wjjeeps.com/tcases.htm
Admittedly I am likely confused.
srode is offline
post #14 of 37 Old 06-30-2011, 08:33 PM
narnwv
narnwv's Avatar
you're seeing "Center Differential" That's the Hi range (all time) of the transfer case.
This doesn't even apply to the OT....
x2 on having teh 12pt 13mm socket. <--do NOT use a cheap socket, or you'll quickly round off those 12 point bolt heads.
~Aaron
narnwv is offline
post #15 of 37 Old 06-30-2011, 08:42 PM Thread Starter
srode
2008 XK Commander
I put PB Blaster on the 13mm bolts last night - broke one loose with a wrench and wrench cheater (adding a 9/16 wrench coupled to it) Have craftsman sockets so not the best - hopefully I can get them off ok - I think all my snap on metrics are 6 point sockets.
this is the line in section 4 at the top of the page I was looking at " Vari-Lok front and rear progressive axles"
srode is offline
CV Joint Replacement....help please. boosoo ZJ Grand Cherokee Forum 6 04-14-2015 05:20 PM
Dana 30 CV Joint to U-Joint Replacement? IdahoZJGuy ZJ Grand Cherokee Forum 7 06-25-2008 03:20 PM
CV Joint replacement Samdweezel05 ZJ Grand Cherokee Forum 3 01-01-2008 02:50 PM
cv joint replacement melvin74 ZJ Grand Cherokee Forum 23 09-23-2007 12:03 AM
CV Joint replacement on 99 WJ scottjclaypool ZJ Grand Cherokee Forum 1 07-09-2004 10:14 PM
