Custom tube bumper - JeepForum.com
post #1 of 56 Old 11-08-2012, 04:37 PM Thread Starter
Maximus_Daximus
1976 CJ7
Custom tube bumper
Heres the finished product, and the journey to get to it follows.
current build 1999 wj
previous build 1976 cj7
Maximus_Daximus is offline
post #2 of 56 Old 11-08-2012, 04:40 PM
chris1999wj
Thats sick nice job
99 wj 4" rcx lift, 275/75/16 kenda m/t km29, safari bull bar, wp safari roof rack, adj. control arms and track bar, rc steering stabalizer
chris1999wj is offline
post #3 of 56 Old 11-08-2012, 04:42 PM
BrekkanD
That's sick! I want that lol. I have the same tires btw
BrekkanD is offline
post #4 of 56 Old 11-08-2012, 04:45 PM Thread Starter
Maximus_Daximus
1976 CJ7
Started off with the idea of morphing the only 2 that I could find togeather.
So with that I looked up diffrent ways of mounting it. Basic layout everyone used was the tow hook space. So we got 1/4" plate to sandwich the opening, matched the holes and welded some 3/8 nuts to it. Trying to just use material we had, we used some right angle tube we bent earlier to calibrate the bender and tacked it to the plate. Following the body line, we bent.up.the main tube and called it a night.
post #5 of 56 Old 11-08-2012, 04:54 PM Thread Starter
Maximus_Daximus
1976 CJ7
Day two the winch showed up which was great since we were waiting on it and the damn bushwackers to build the bumper.
Using 3/8 plate, we made the winch plate and tacked it down and.installed the winch so we could build around it.
Attachment 504063
With that all settled in we started.the next rail. Now if I were to.do.tjis again, we would have.done it.diffrently, mainly because the.hand plasma died and we had to knock this **** buy hand with a die grinder like 30x.
Click image for larger version
Attachment 504064
Attachment 504067
post #6 of 56 Old 11-08-2012, 05:01 PM
Thomahawk
2006 XK Commander
Thumbsup! Nice work, drool.
Buildthread
Thomahawk is offline
post #7 of 56 Old 11-08-2012, 05:15 PM Thread Starter
Maximus_Daximus
1976 CJ7
Next step was the bottom and.the.tie ends this part went by quick.
Attachment 504090
Attachment 504086
Attachment 504087
Attachment 504088
Then we just came up with a basic arch for the stinger. We ended up.knotching it to fit over the outer hoop.
Attachment 504089
Attachment 504091
Then we cnc a front winch plate out of 1/4" plate for the fairlead.
Then we designed the side fillers with the M/M metal mulisha logos in it.
post #8 of 56 Old 11-08-2012, 05:27 PM Thread Starter
Maximus_Daximus
1976 CJ7
Next part was the fun part, time cnc the 1" shackles. I knotched out.the front tubes to insert the shackle mounts into, and also drilled 1/2" holes in the.back to.plug weld.for.extra strength.
post #9 of 56 Old 11-08-2012, 05:41 PM Thread Starter
Maximus_Daximus
1976 CJ7
I scored some nice l.e.ds from phantom trailhawk. I took them all.apart and removed them from the cases. I then put them up to.the bumper and mounted them flush.
It literally took me 30 mins to figure.out how to turn on the fog lights since.thats what I wired them into.
post #10 of 56 Old 11-08-2012, 05:48 PM Thread Starter
Maximus_Daximus
1976 CJ7
Then a little birdie advised me to upgrade the mounts and take them all the way back.to.the sway.bar mounts.
Before
After
post #11 of 56 Old 11-08-2012, 05:49 PM
gcjeeping
gcjeeping's Avatar
I see you hoop tied into where the tow hooks go. Did you tie the winch plate into anything else? If so post up pics of the other attachment points.
_____________
gcjeeping is offline
post #12 of 56 Old 11-08-2012, 05:57 PM Thread Starter
Maximus_Daximus
1976 CJ7
We also made tabs on the side to tie into the stock bumper locations. Added tubes to meet up.with the.fender flares. powdercoated then installed everything. Extreamly happy with.how it turned out.
ForumRunner_20121108_184836.jpg   ForumRunner_20121108_184850.jpg   ForumRunner_20121108_184929.jpg
post #13 of 56 Old 11-08-2012, 05:58 PM Thread Starter
Maximus_Daximus
1976 CJ7
Yea tied the stinger into.the tow hook location as well. Theres tabs on.the.bottom and.in.the back as well, cant see. It with the winch installed
post #14 of 56 Old 11-08-2012, 06:41 PM
tsneath
Looks awesome now make us all one. Lol
tsneath is offline
post #15 of 56 Old 11-08-2012, 07:06 PM
CoastieShep
Very nice. Like how the winch is hidden and protected.
CoastieShep is offline
