Creaking Noise when Shifting Automatic Transmission - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Creaking Noise when Shifting Automatic Transmission
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 08-05-2010, 09:01 AM   #16
00RedWJ
2006 WK
Originally Posted by rspina View Post
I think my final verdict was the brakes. The sound was absent when shifting without the brakes applied. Sure lost a few nights of sleep over it though.
I'm Still not sure about that Is the jeep lunging forward and backwards when you go in drive and reverse without the brakes? It's possible that the torque energy is being relieved through the wheels instead of the drivetrain mounts when you don't engage the brakes
2000 Red Grand Cherokee Laredo WJ
4.0 with Selec-trac
Sold 1-2013
2006 Black Grand Cherokee Laredo WK
3.7 with 65,000 Miles
00RedWJ is offline   Reply With Quote
Unread 08-05-2010, 12:56 PM   #17
bigbossd1030
bigbossd1030's Avatar
Glad to help out
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
bigbossd1030 is offline   Reply With Quote
Unread 08-05-2010, 01:20 PM   #18
1AAdam
my 00 and 01 wj's both do it. just figured it was the brakes and forgot about it. glad it wasn't something more serious!
1AAdam is offline   Reply With Quote
Unread 08-05-2010, 01:38 PM   #19
lipripper
My 01 makes the same noise, you get used to shifting and letting up the brake. I'm going to through new rotors and pads in the back and see if that cures the problem. But I agree with the rear brakes using a fraction of the pressure of the front, but it should be enough to hold the GC without creeping. I'll keep you posted when I swap out the rotors.
lipripper is offline   Reply With Quote
Unread 08-05-2010, 01:49 PM   #20
thnksno
My rear pads were down to the metal backer and it creaked something fierce... After changing discs and pads, I was disappointed to find the creaking still happening. But it is much LESS than it was.
thnksno is offline   Reply With Quote
Unread 08-05-2010, 02:21 PM   #21
Mighty Thor
One way to ensure that the back brakes are grabbing fully is to engage the parking brake and the foot brake then shift the transmission and see if the noise is still there. IF you have the back tires locked down hard and it still makes the noise it is the driveline loading that makes the noise and it is a combination of many things including Tranny servos, bushing flex, Ujoint flex, slip joint flex, ball joint flex and pinion lash.
Mighty Thor is offline   Reply With Quote
