cranks and sputters. - JeepForum.com
post #1 of 9 Old 10-21-2013, 04:59 AM Thread Starter
Bishie336
Wj cranks and sputters.
Hi,My 4.0 l6 sputters when i attempt to start and cuts off instantly.It started with Intermittent Crank sensor and injector 1 fault codes.It then died completely. I changed the injectors with upgraded 4 hole type and CPK.It jst didnt work.Now the fault codes cant disply coz I had removed the battery terminals.
I realy dnt knw what to do.Can someone assist
Bishie336 is offline
post #2 of 9 Old 10-21-2013, 05:22 AM
Duh
Check fuel pressure. Sputtering often means low fuel into cylinders.
Duh is offline
post #3 of 9 Old 10-21-2013, 01:22 PM
new2site
Your battery's voltage is quite possibly low...it should test at 12.6 resting voltage (not running). These WJ PCM's demand top rate voltage...if it's even on a low side they'll do what yours is doing --engine will crank...but when started will just sputter out. If you have access to another battery from other vehicle with close cranking amp rating give it a shot...don't shut hood while testing this as WJ's have very little clearance between battery and hood (in case test battery is on "tall side")
Post back follow up results..
new2site is offline
post #4 of 9 Old 10-21-2013, 01:29 PM
cykaaro
While in there worth cleaning the battery connectors, ground from battery on the engine side, and engine to firewall. This will just know you're getting a good connection and isn't part of the problem.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #5 of 9 Old 10-22-2013, 12:15 PM
new2site
Update?
new2site is offline
post #6 of 9 Old 10-30-2013, 12:57 AM Thread Starter
Bishie336
Thanks for your tip guys.I will try them out.I noticed one more thing though.The NGK spark plugs (#ZFR5N) currently fitted have a gap of 0.90 as opposed to the recommended Champion spark plugs (#RC12ECC- copper plus) which has a gap of 0.36.Could this be contributing to the problem?
post #7 of 9 Old 10-30-2013, 08:34 AM
ChrisHager
Administrator
ChrisHager's Avatar
Woah! Definitely re-gap them!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #8 of 9 Old 10-30-2013, 01:02 PM
rdkendrick
2003 WJ
CLEANING AND GAPPING (Except HO engines)
The plugs may be cleaned using commercially available spark plug cleaning equipment. After cleaning, file center electrode flat with a small point file or jewelers file before adjusting gap. The Gap specification is 0.035 for the 4.0L engine, and 0.040 for the 4.7L engine.
CAUTION: Never use a motorized wire wheel brush to clean spark plugs. Metallic deposits will remain on spark plug insulator and will cause plug misfire.
Sent from my iPad using my fingers
rdkendrick is offline
post #9 of 9 Old 10-30-2013, 02:27 PM
Jeepforthewin
2010 JK Wrangler
X2!! Gap plays a pretty big role!
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
