-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   cranks and sputters. (http://www.jeepforum.com/forum/f310/cranks-sputters-1706186/)
Bishie336 10-21-2013 04:59 AM
Hi,My 4.0 l6 sputters when i attempt to start and cuts off instantly.It started with Intermittent Crank sensor and injector 1 fault codes.It then died completely. I changed the injectors with upgraded 4 hole type and CPK.It jst didnt work.Now the fault codes cant disply coz I had removed the battery terminals.
I realy dnt knw what to do.Can someone assist
Duh 10-21-2013 05:22 AM
Check fuel pressure. Sputtering often means low fuel into cylinders.
new2site 10-21-2013 01:22 PM
Your battery's voltage is quite possibly low...it should test at 12.6 resting voltage (not running). These WJ PCM's demand top rate voltage...if it's even on a low side they'll do what yours is doing --engine will crank...but when started will just sputter out. If you have access to another battery from other vehicle with close cranking amp rating give it a shot...don't shut hood while testing this as WJ's have very little clearance between battery and hood (in case test battery is on "tall side")
Post back follow up results..
cykaaro 10-21-2013 01:29 PM
While in there worth cleaning the battery connectors, ground from battery on the engine side, and engine to firewall. This will just know you're getting a good connection and isn't part of the problem.
new2site 10-22-2013 12:15 PM
Update?
Bishie336 10-30-2013 12:57 AM
Thanks for your tip guys.I will try them out.I noticed one more thing though.The NGK spark plugs (#ZFR5N) currently fitted have a gap of 0.90 as opposed to the recommended Champion spark plugs (#RC12ECC- copper plus) which has a gap of 0.36.Could this be contributing to the problem?
ChrisHager 10-30-2013 08:34 AM
2 Attachment(s)
Woah! Definitely re-gap them!
rdkendrick 10-30-2013 01:02 PM
CLEANING AND GAPPING (Except HO engines)
The plugs may be cleaned using commercially available spark plug cleaning equipment. After cleaning, file center electrode flat with a small point file or jewelers file before adjusting gap. The Gap specification is 0.035 for the 4.0L engine, and 0.040 for the 4.7L engine.
CAUTION: Never use a motorized wire wheel brush to clean spark plugs. Metallic deposits will remain on spark plug insulator and will cause plug misfire.
Sent from my iPad using my fingers
Jeepforthewin 10-30-2013 02:27 PM
X2!! Gap plays a pretty big role!
The time now is 06:20 AM.
