Crank position sensor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Crank position sensor
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 07-09-2012, 05:22 PM   #1
PathWJ99
So I replaced the fuel pump, filter, and new gas lines, and spark plugs. I started her and and she ran great. Let the car run for 20 mins. Then drove for about 5 miles. I parked the car and let it sit for a good three hours. Got in started up fine drove fine then died on me again. Please someone help me. I'm getting to the end of my rope with this ****. I just read that it could be the CPS. Is this something that sounds right?
PathWJ99 is offline   Reply With Quote
Unread 07-09-2012, 05:35 PM   #2
robby65
Did you pull any codes ?
robby65 is offline   Reply With Quote
Unread 07-09-2012, 06:00 PM   #3
PathWJ99
No. That's the part that sucks.
Unread 07-09-2012, 07:46 PM   #4
brewer2
Sounds like you need to start with the basics do you have squish bang and exhaust?
Brewer2... Formerly known as brewer
Beauty is just a light switch away :)
brewer2 is offline   Reply With Quote
Unread 07-09-2012, 09:34 PM   #5
PathWJ99
What's that?
Unread 07-09-2012, 10:22 PM   #6
KTMrida4life
Originally Posted by PathWJ99 View Post
What's that?
Suck bang and blow! haha
What an engine needs to run. Air fuel and spark. Literally, the very very basics. Applies well to lawnmowers/2 stroke engines/4 stroke engines/carbureted cars but doesnt apply all that well to a fuel injected computer controlled car. Way too many other factors.
KTMrida4life is offline   Reply With Quote
Unread 07-09-2012, 10:30 PM   #7
PathWJ99
The fuel pump, fuel filter, spark plugs and air filter are all new. The throttle body is cleaned and the iac is 8 months old. I have been looking online for about 5 hours now and about one hundred people said that the crank position sensor fixed the problem so I'm gonna get that done soon!
Unread 07-09-2012, 11:50 PM   #8
KTMrida4life
What does it do when you try to start it? Crank and crank, or nothing?
Unread 07-10-2012, 12:49 AM   #9
PathWJ99
Sometimes starts right up and other times crank crank crank. But if I let it sit for a little bit then it starts right up.
Unread 07-10-2012, 02:21 AM   #10
PhantomWJ
2003 WJ
So, aside from the cranking issues...did it ever die/ cut iff in you?
PhantomWJ is offline   Reply With Quote
Unread 07-10-2012, 06:02 AM   #11
PathWJ99
Yes. Pretty much at least once day while I'm driving.
Unread 07-10-2012, 07:53 AM   #12
noeffort
Use a Mopar CPS.
2002 Grand Cherokee Laredo 4x4 4.0
noeffort is offline   Reply With Quote
Unread 07-10-2012, 09:32 AM   #13
PhantomWJ
2003 WJ
Ok. Imma going through the same drama. The crank position sensor is my next step.
Unread 07-10-2012, 09:43 AM   #14
PathWJ99
What did you replace so far to try and fix it? A lot of people are having the same problems with there wj's
Unread 07-10-2012, 09:55 AM   #15
PhantomWJ
2003 WJ
same items you mentioned above, less the plugs. I though it was my pump so I replaced it...it didnt work, or it did just didnt fix the stalling issue and not cranking over issue. So i dropped the tank and got showered with fuel, hence telling me there is plenty of pressure and fuel pump is working. I have been researching since last week.
Im not sure if ima wait on a MOPAR CPS or go get a BWD at PepBoys, but in either case that is next on the list.
