Coolant Won't Drain!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Coolant Won't Drain!!!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!
Unread 04-18-2004, 12:02 PM   #1
Astorm
I was trying to do a coolant flush on my 00 JGC today, so i took off the radiator cap, got the drain pan ready, and opened the drain plug.........nothing. It won't flow out. I took off the coolant bleed fitting, and it still won't drain. It has the drain plug with a hose coming out the bottom. The drain valve only turns a quarter turn and then stops. Any Ideas?
Andy
2000 JGC Limited 4.7
Quadra-Drive
Addco
Flowmaster 50-Series
K&N FIPK/RamIt
Every Option
Astorm is offline   Reply With Quote
Unread 04-18-2004, 01:21 PM   #2
greasefingers
1994 ZJ
Yank off the lower radiator hose. Then once the fluid is out you will have to determine if the lower portion of the radiator is clogged? A new radiator is not such a bad thing. It keeps your trany cool as well; plus hot summer days are just around the corner
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
