Coolant Won't Drain!!! - JeepForum.com
post #1 of 2 Old 04-18-2004, 01:02 PM Thread Starter
Astorm
I was trying to do a coolant flush on my 00 JGC today, so i took off the radiator cap, got the drain pan ready, and opened the drain plug.........nothing. It won't flow out. I took off the coolant bleed fitting, and it still won't drain. It has the drain plug with a hose coming out the bottom. The drain valve only turns a quarter turn and then stops. Any Ideas?
Andy
2000 JGC Limited 4.7
Quadra-Drive
Addco
Flowmaster 50-Series
K&N FIPK/RamIt
Every Option
Astorm is offline
post #2 of 2 Old 04-18-2004, 02:21 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Yank off the lower radiator hose. Then once the fluid is out you will have to determine if the lower portion of the radiator is clogged? A new radiator is not such a bad thing. It keeps your trany cool as well; plus hot summer days are just around the corner
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
Radiator Drain Plug? Coolant wont drain epfriis ZJ Grand Cherokee Forum 6 06-18-2015 01:18 PM
Coolant Drain Plugs? 95JpGC ZJ Grand Cherokee Forum 6 07-17-2006 05:04 AM
Is there another way to drain the coolant in a 93 grand jeep cherokee v8 5.2? jayalvarez ZJ Grand Cherokee Forum 2 03-25-2005 02:22 PM
Coolant Engine Drain PLug -Joe- ZJ Grand Cherokee Forum 3 02-20-2005 04:56 PM
6 Cyl engine coolant drain plug . . . ? Humberto Benavides ZJ Grand Cherokee Forum 2 02-24-2002 11:55 PM
