coolant bleeder stuck! - JeepForum.com
 2Likes
post #1 of 32 Old 06-02-2011, 01:08 PM Thread Starter
mckoolkid
Exclamation coolant bleeder stuck!
iv got a 99 4.7 and the coolant bleeder is stuck, i just put a new water pump and radiator and thermostat in. i couldnt manage to get it open so i ran the engine up to operating temp. with the radiator cap off and filled it as it went down. is this ok? or do i need to be looking into getting the bleeder open?
also im not sure if my e-fan is working or not? i havnt seen it move since around winter time. is there a good way to check it and what are the normal reasons it would crap out on me.
Any help is appreciated!
Thanks
Alex
mckoolkid is offline
post #2 of 32 Old 06-02-2011, 01:35 PM
1AAdam
the typical reason for the e-fan not working is that pesky relay they hid under the headlight. maybe use a test light and test for power at the plug for the fan and then move back from there. sorry, can't help u on the bleeder.
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #3 of 32 Old 06-02-2011, 02:39 PM Thread Starter
mckoolkid
does that relay really cost 112 bucks! i just ran to the dealership and thats what they quoted me for... and for some reason its is still running around 212... i thought it would drop down it actually went up after the radiator, pump and thermostat. im thinking about saying screw the relay for now and putting in a switch. obviously id have to turn it off when i park the truck but would this hurt anything?
post #4 of 32 Old 06-02-2011, 04:28 PM
Thomahawk
Ha ha, never Go to stealership its notmckool kid
Buildthread
Thomahawk is offline
post #5 of 32 Old 06-02-2011, 04:32 PM
flyboy14295
Thanks
Alex
What bleeder...
You fill the Rad, let the engine warm to operating temp. Air bubbles will be pushing out while this happens. The t-stat will open and your level will drop dramatically. Fill it up until air stops coming out. Put cap back on. Done.
WJ. 4.Slow I6. The Underdog
2" Teraflex BB, 265/70R16 BFGoodrich TA KO's, JKS Adjustable Track Bar, JKS HD Tie Rod, Rusty's Tow Hooks, Block Heater, CB
New York City EMS
Originally Posted by LoneJeeper View Post
I came into this world via broken rubber, i'm not going out the same way.
flyboy14295 is offline
post #6 of 32 Old 06-02-2011, 09:14 PM
86cj74.2L
86cj74.2L's Avatar
heat it with a propane torch with a medium flame next time you drain system. When you first apply heat you will see moisture/water drops form. continue untill the moisture burns off, then hit it with penitration oil of your choice and try and remove it. It may take a couple tries.
my friends GMC has the same bleeder setup and his required more heat then expected to loosen, but it came out without messing the allen wrench hole in the plug.
86cj74.2L is offline
post #7 of 32 Old 06-02-2011, 09:26 PM
HVACNY
2013 WK
Im just curious if your clutch fan is working properly?It kinda balances out the temp until the efan comes on.
Also maybe spray some PB Blaster on the bleeder plug,should make it turn if its frozen.
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline
post #8 of 32 Old 06-02-2011, 09:59 PM
narnwv
narnwv's Avatar
You will get a check engine light without the relay in tact.
Originally Posted by flyboy14295 View Post
What bleeder...
The one on top of the timing cover, where the top radiator hose is. You have to bleed from there AND the radiator, or you'll never get all the air out.
~Aaron
narnwv is offline
post #9 of 32 Old 06-03-2011, 04:25 AM
Apollo21
This is very true trust me. My first time getting it out was a PIA. Get a cheater and use some PB. I only hand tighten it now.
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #10 of 32 Old 06-03-2011, 04:52 AM
xJoshxx
2012 WK
What bleeder...
4.7's have a Bleeder on the driver side upper radiator hose.
4.0L's the fill and run method works.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #11 of 32 Old 06-03-2011, 09:00 PM
MikeeN
2003 WJ
so i went to remove my bleeder plug today and realized it is completely rounded... sooo what now? haha im jsut not quite sure what to do at this point to remove it kinda same deal as op i guess?!
MikeeN is offline
post #12 of 32 Old 06-03-2011, 10:59 PM
HVACNY
2013 WK
Weld a nut to the raised portion of the plug,and put a wrench on the nut and unscrew it.
HVACNY is offline
post #13 of 32 Old 06-03-2011, 11:13 PM
MikeeN
2003 WJ
what if i dont have access to a welder?
MikeeN is offline
post #14 of 32 Old 06-04-2011, 04:34 AM
xJoshxx
2012 WK
then your buying a new part?
2011 WK2 ORA2 sold
xJoshxx is offline
post #15 of 32 Old 06-04-2011, 06:44 AM
4Tom
I would be inclined to leave it alone.
I'm nearly sure if you run the engine with the refill bottle open it burp itself
Just run it long enough until the thermostat opens.
I don't have a 4.7 so you will need to have this confirmed
WJ 2001 3.1TD
Tom
4Tom is offline
Low coolant grovesj2 WJ Grand Cherokee Forum 2 05-09-2011 01:43 PM
Coolant Bleeder Screw drwolcot WJ Grand Cherokee Forum 12 03-31-2011 03:15 PM
Coolant CBlakeNS WJ Grand Cherokee Forum 2 02-21-2011 07:38 PM
Coolant Low Grdaemon WJ Grand Cherokee Forum 12 01-02-2011 02:40 AM
What coolant? (UK) hampshirejeep WJ Grand Cherokee Forum 3 10-06-2010 03:57 PM
