Control Arm Bushings Coming Out? - JeepForum.com
post #1 of 14 Old 05-16-2011, 08:43 PM Thread Starter
billzcat1
Chicken in a Turkey Suit
2003 WJ
Take a look at this:
Passenger side upper control arm/axle bushing
Driver's side upper control arm bushing
Drivers side lower control arm bushings
Every control arm bushing I've seen has been pressed in all the way up to the flange. These look like they are not all the way in or well on their way toward falling out (especially driver's side upper). Thoughts?
~Richard
billzcat1 is offline
post #2 of 14 Old 05-16-2011, 09:33 PM
negativecreep
Kinda curious about this myself. I just noticed something similar while looking for the source of some clunking sounds.
negativecreep is offline
post #3 of 14 Old 05-16-2011, 09:41 PM Thread Starter
billzcat1
2003 WJ
I am getting married in two weeks and taking a road trip for the honeymoon. I wasn't planning on dropping an axle before then. Anyone have any thoughts on this?
~Richard
post #4 of 14 Old 05-16-2011, 11:16 PM
narnwv
narnwv's Avatar
um, congratulations?
in all seriousness, one of mine looks just like that, and I think it should be pushed in to the "lip" of the bushing. Just my $0.02
~Aaron
narnwv is offline
post #5 of 14 Old 05-17-2011, 06:49 PM Thread Starter
billzcat1
2003 WJ
Can I get someone to check what the FSM says about pressing in control arm bushings? Or even someone to look at their axle and say "yup looks like that" or "nope, pressed all the way in"? Either of those would be a big help.
~Richard
post #6 of 14 Old 05-17-2011, 06:57 PM
TJSWJ
i just took my axles out earlier today, let me go check for you. give me a min
TJSWJ is offline
post #7 of 14 Old 05-17-2011, 07:01 PM
malibubts
Just checked my FSM and it doesn't say anything really about the control arms. Just how to remove them. The only thing it mentions about the bushings is which bushing goes where.
malibubts is offline
post #8 of 14 Old 05-17-2011, 07:02 PM
Steve01WJ
2005 WK
Mine look like that and I get alot of clunking over bumps. I have the same issue or sway bushings. Ill Follow
12 JKU, 2.5TF BB, MTR 35s on 15"procomps
05 WK 5.7 Limited QD2
Steve01WJ is offline
post #9 of 14 Old 05-17-2011, 07:02 PM
TJSWJ
the pass upper bushing is pressed in with the lip of the bushing flush against the axle housing, the driver upper bushing has a 1/2 inch between the lip of the bushing and the axle housing. The lower control arm bushings have 3/8 in between the lip of the bushing and the control arm. So it looks to me like your bushings are fine.
TJSWJ is offline
post #10 of 14 Old 05-17-2011, 07:57 PM Thread Starter
billzcat1
2003 WJ
I just changed sway bar bushings to brand new OEMs. That helped with body roll as the originals were quite squishy. I've narrowed down the clunking to the JKS QDs which is really disappointing. Thank you for the reassurance, fellas!
~Richard
post #11 of 14 Old 05-17-2011, 08:06 PM
narnwv
narnwv's Avatar
Some local guys have complained about the clunks from JSK QDs on other Jeeps.
~Aaron
narnwv is offline
post #12 of 14 Old 05-17-2011, 08:14 PM Thread Starter
billzcat1
2003 WJ
Well they are for sale. RCs on the way. If anyone wants them, they are more than half off what I paid. They are certainly strong and very easy to remove when needed. I would just hate to throw them away when I know there are people out there buying them new.
~Richard
post #13 of 14 Old 05-17-2011, 09:25 PM
JakeWJ
I've started collecting parts to do a 2" BDS lift (thanks in large part to your write-up, ), and have been putting off ordering sway links. I'm hoping to keep it "clunk and rattle" free, and I would hate to have those making noise up front. I had only really considered the Zone fixed links for 2-3" lift, or the JKS quickers. Of course the Zone are not quick disconnect, but that should mean no noise.
I haven't seen any feedback on the RC ones. The site says they are for 3-6" lift, but I suppose they'd be fine with a .75" spacer up front. Price is pretty good too. I'll be curious to see how you think they compare to the JKS set.
JakeWJ is offline
post #14 of 14 Old 05-17-2011, 10:06 PM Thread Starter
billzcat1
2003 WJ
I'll definitely report my findings. They should be fine at 2" lift as well. The sway bar might sit at a bit lower of an angle than it should, but not by much. I did read from one fellow that broke one recently (they are a LOT thinner than the JKS parts) but RC replaced it right away. If you wheel with them discoed then they will have a lot less stress. Street driving for a month is a lot less stressful than a day of wheeling.
~Richard
Control Arm Bushings myjeeplovesmud WJ Grand Cherokee Forum 48 06-18-2012 10:12 AM
Upper control arm bushings, front and rear sinbad85 WJ Grand Cherokee Forum 5 02-09-2011 02:48 PM
WJ Rear Upper Control Arm Bushings Bubba3200 WJ Grand Cherokee Forum 27 10-17-2010 06:55 PM
Where can i get Bushings? blazepsi WJ Grand Cherokee Forum 4 10-04-2010 07:25 PM
Wanting WJ upper control arm bushings at the axle, not found. crashcraddock WJ Grand Cherokee Forum 10 04-30-2010 08:56 AM
