control arm bushings - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > control arm bushings
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Solution to Radius Arm Bind - Meet Lock-N-LoadFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-05-2014, 08:20 PM   #1
behappynwise
Jeep has new shocks away bar bushings front and back trailing arms. Still a clunk in back and play in back wheel. Going to need control arm bushing and such. Looking for good prices and to make my mechanics life easier .
behappynwise is offline   Reply With Quote Quick reply to this message
Unread 06-05-2014, 10:07 PM   #2
Mp5ben
Back WHEEL movement? Control arms won't be related to actual wheel movement. I'd imagine that be related to worn wheel bearings or loose lug nuts haha
However if you mean you are replacing the real lower control arms, its usually much easier to replace the whole control arm rather than replacing the two individual bushings. Check rockauto .com
Mp5ben is offline   Reply With Quote Quick reply to this message
Unread 06-06-2014, 04:25 AM   #3
derekmac
derekmac's Avatar
Yeah, you'll pay just about the same replacing the bushings as you will getting new arms, maybe more if you need to have a shop put them in. The rear lower arms are just over $20 each from Rockauto.
2002 WJ Olympics Commemorative Edition
245/70-17 Duratracs
2" BB
Future: 4" lift and lockers
Build thread.
http://www.gofundme.com/d8jlwo
derekmac is offline   Reply With Quote Quick reply to this message
Unread 06-06-2014, 05:17 AM   #4
behappynwise
That's not bad. The wheel has a front to back play. Wheel bearing is new as I had to fix the axle seal. It clunks too
Unread 06-06-2014, 08:36 AM   #5
ChrisHager
ChrisHager's Avatar
Does the wheel alone or the whole axle move front to back? By front to back, I assume you mean towards the front of the vehicle and towards the rear of the vehicle or is it moving into the axle tube/out of the axle tube?
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
ChrisHager's 'Grilled' Thread
WJ Torque Specs
Originally Posted by tommyooooooh View Post
But ChrisHager makes me want to poor water on a burning bucket of gasoline now just out of curiosity.
Originally Posted by billzcat1 View Post
The latest lift kit from Rough Country? :D
Originally Posted by Jeeples View Post
Your symptoms sounds just like what it does when it's not doing what it should because of how it is.
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 06-06-2014, 08:42 AM   #6
behappynwise
Towards front to back.
Unread 06-06-2014, 08:52 AM   #7
ChrisHager
ChrisHager's Avatar
Wheel only or entire axle?
Hers: 2000 TJ
WJ Torque Specs
Unread 06-06-2014, 09:00 AM   #8
behappynwise
Sorry. It was done with all tires on the ground by gripping the tire and moving. Unsure what was moving but when you hit a bump it does bang and you can almost feel the movement almost like a bushing would be gone if you know what I mean. It's the only thing I haven't fixed yet.
Unread 06-06-2014, 09:02 AM   #9
ChrisHager
ChrisHager's Avatar
Roger that. Assuming the axle bearings are in good shape, the control arm bushings make sense.
Hers: 2000 TJ
WJ Torque Specs
Unread 06-14-2014, 09:57 AM   #10
behappynwise
No noises other than a clunk assuming they are ok
Unread 10-15-2014, 11:05 PM   #11
behappynwise
Still have to get these done. Rock auto seems like a good price, but when you factor in shipping its expensive.
