Control Arm Bushings - JeepForum.com
post #1 of 8 Old 10-03-2013, 10:47 AM Thread Starter
peytonimor7
I need to replace all control arm bushings and I can't decide if it'd be easier to just buy all new control arms. In terms of cost/ease of application which would be the best way to go?
l 04 WJ l OME HD+3/4" spacers l Bilstein 5100 l 245/70/17 Firestone M/Ts l IRO A-Arm & CAs F & R l
peytonimor7 is offline
post #2 of 8 Old 10-03-2013, 09:06 PM Thread Starter
peytonimor7
bump
post #3 of 8 Old 10-03-2013, 09:08 PM
JeepinJeremy
rockauto.com. Cheap new brand name arm with bushings. MOOG make a nice stock replacement
JeepinJeremy is offline
post #4 of 8 Old 10-03-2013, 10:45 PM
mtnhigh
^^ arms are totally worth it.
mtnhigh is offline
post #5 of 8 Old 10-03-2013, 11:21 PM Thread Starter
peytonimor7
Any other manufacturer suggestions? I was thinking of going with the Moog's anyway as I know they are of pretty good quality.
EDIT: I have an OME HD lift, will probably put 3/4 in spacers all the way around, any thoughts on aftermarket arm setup?
post #6 of 8 Old 10-04-2013, 08:56 AM
Merc1973
I would go with IRO adjustable short arms (what I am currently using), at least up front since you will be adding the spacers to your OME lift. I initially went with cheap replacement arms and D30 axle bushings, they didn't last a year. NAPA has the high quality line called "Napa Chassis Parts" (NCP) which uses Clevite Rubber in the bushings (same as MOPAR) for about $100 each. Those would be my choice. Or if you want to keep OEM, the MOPAR replacements are about $120+ each online.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #7 of 8 Old 10-04-2013, 01:44 PM
Kolak
Vendor
Kolak's Avatar
I second the suggestion of the IRO adjustable arms since your Jeep is lifted.
Send me a PM here on the forum or email me at kolak@aol.com - I'm an IRO dealer and I also have nice replacement stock arms/bushings if you need them for any of the other positions.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #8 of 8 Old 10-06-2013, 06:51 PM Thread Starter
peytonimor7
Should long arms be avoided with this short of a lift?
