Condensate Drain Access - JeepForum.com
post #1 of 7 Old 06-13-2013, 10:02 PM Thread Starter
jawilson20
I have what appears to be the common passenger floorboard lake due to the poor design of the condensate drain.
I have read many threads on many boards, and it seems the best fix is to extend the length of the drain tube. However, I have absolutely no idea how to access it. I have seen that on other models the frame had to be cut in order to access the drain. Is this the case on the WJ as well? If so, I suppose that I will initially try sealing the hole from the interior with caulk. Is regular silicone going to be the best bet in this instance?
jawilson20 is offline
post #2 of 7 Old 06-13-2013, 10:19 PM
narnwv
narnwv's Avatar
Clean it out first:
http://www.jeepforum.com/forum/f13/z...ml#post3885949
~Aaron
narnwv is offline
post #3 of 7 Old 06-14-2013, 07:19 AM Thread Starter
jawilson20
Originally Posted by narnwv View Post
Thanks for the reply. I have found plenty of threads on drilling through from the inside of the car. However, a lot of those threads seem to suggest that often times the drain is not actually clogged and the problem persists until they are able to extend the length of the hose.
I would like to try the option that doesn't require drilling through anything if possible first. That is where I am lost, for those that have extended the hose length, how on earth do you get to it? I can see it from under the car, but there is no logical way I can see how to get to it.
post #4 of 7 Old 06-14-2013, 07:35 AM
narnwv
narnwv's Avatar
Extending it will not unclog it.
You can extend it 400 feet if you want, but the passenger floor will continue to get wet until you unclog it.
~Aaron
narnwv is offline
post #5 of 7 Old 06-14-2013, 10:18 AM
oldfamilyguy
If its not clogged then extending it and sealing the firewall opening from the outside will definately solve it. Run vehicle parked with a/c on long enough to generate some water and observe if its dripping to the ground. You can look up and see where it exits through the firewall. If it is then you're not clogged and its likely a/c water getting wind blown back through the firewall when you're rolling. I fixed mine with an elbow shaped rubber extender made for this type application on dodge caravans and totally sealed all around on the outside of the firewall with silicone. Totally dry since then. For sure it was very awkward to get at but do able and I have big hands. It was awhile ago but I think I remember considering dropping the starter to gain some work room but managed without. And if it looks to be clogged, you can still access it with a wire to poke around in there from the outside opening.
oldfamilyguy is offline
post #6 of 7 Old 06-20-2013, 03:11 PM Thread Starter
jawilson20
I proceeded with drilling through the back side of the drain in order to clean out the drain line and as expected, the leak has continued.
What is the next course of action? I am thinking of trying to remove the foam gasket and resealing the pass through with caulk. Thoughts?
post #7 of 7 Old 06-21-2013, 01:59 PM Thread Starter
jawilson20
OK... Guess I will be removing the gasket and attempting to reseal this weekend! Wish me luck!
