The Comprehensive BDS/FatBob's 2" Lift Thread - Page 40 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > The Comprehensive BDS/FatBob's 2" Lift Thread
Unread 08-28-2013, 09:40 PM   #586
WiLieR
A double cardan is a type of cv joint. There several different types of "constant velocity" joints.
http://en.wikipedia.org/wiki/Constant-velocity_joint
Tossed onto the interwebs via iPhone
99 WJ Laredo - Mine once again!
WiLieR is offline   Reply With Quote Quick reply to this message
Unread 08-28-2013, 11:41 PM   #587
billzcat1
Chicken in a Turkey Suit
2003 WJ
Yes, a Double Cardan joint IS a type of Constant Velocity joint. But in common vernacular, the Rzeppa joint is often just called the CV joint because it is essentially the "textbook" constant velocity joint. Most of the time I call it a Rzeppa joint, but around here if someone says CV, assume they mean Rzeppa.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 09-01-2013, 04:08 PM   #588
Ravie
Yes.
1999 WJ - Over 10k on the 4.0 rebuild. FB/BDS 2" lift (2.5") w/Bilstein 5125's. General Class Ham...KC0LUA
Burlbook48 sez "Nothing moves a project along faster than cubic dollars." Certified Thread Killer.
Ravie is offline   Reply With Quote Quick reply to this message
Unread 02-22-2014, 07:11 PM   #589
Jrboarder27
thinking of purchasing this lift and was wondering if any one can tell me about the "performance 8000" shocks option. Im not expecting any thing amazing just wondering, more so in terms of on road handling.
Jrboarder27 is offline   Reply With Quote Quick reply to this message
Unread 02-23-2014, 03:24 AM   #590
Thomahawk
Thomahawk's Avatar
Nah, you would be more happy with some Bilsteins, do it right first time.
Buildthread http://www.jeepforum.com/forum/f197/...grade-1813490/
Thomahawk is offline   Reply With Quote Quick reply to this message
Unread 02-23-2014, 01:25 PM   #591
Jrboarder27
Yeah I've heard enough about bilsteins to know they're great but there not in my budget that's why. I was Asking about the " performance 8000"
Sent from my Galaxy S4 using JeepForum
Unread 02-23-2014, 02:18 PM   #592
Kolak
Vendor
Kolak's Avatar
I have some good budget friendly shocks available that don't ride harshly and perform well. PM me if you'd like to chat.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
kolak@aol.com or kolak@kolakperformance.com
Kolak is online now   Reply With Quote Quick reply to this message
Unread 04-13-2014, 05:16 PM   #593
yellowismellow
Custom User Title
yellowismellow's Avatar
Has anyone installed this lift with a 247 t-case? I'm currently replacing all the control arms on my wife's 2004 wj saving the rear A-arm for last.
I already have new isolators, and am now thinking about putting this lift setup on as well. The front driveshaft is where I'm concerned: rezeppa at the t-case, u-joint at the front axle. I am going to tackle rebuilding the rezeppa soon. My question, how is anyone with this style driveshaft holding up?
I'm pretty stoked to be lifting her wj. Lower control arms alone were toast, add replacing them today firmed some looseness up. It'll be nice to totally revamp everything. I even scored a set of rubicon moabs from a local jk owner.
What size tire can be run on this wheel and lift setup(prefer NOT to use spacers if I can)?
Thanks guys for all the help
2006 TJ Sport
2004 WJ Special Edition
yellowismellow is offline   Reply With Quote Quick reply to this message
Unread 04-13-2014, 11:03 PM   #594
Upside
Originally Posted by yellowismellow
Has anyone installed this lift with a 247 t-case? I'm currently replacing all the control arms on my wife's 2004 wj saving the rear A-arm for last. I already have new isolators, and am now thinking about putting this lift setup on as well. The front driveshaft is where I'm concerned: rezeppa at the t-case, u-joint at the front axle. I am going to tackle rebuilding the rezeppa soon. My question, how is anyone with this style driveshaft holding up? I'm pretty stoked to be lifting her wj. Lower control arms alone were toast, add replacing them today firmed some looseness up. It'll be nice to totally revamp everything. I even scored a set of rubicon moabs from a local jk owner. What size tire can be run on this wheel and lift setup(prefer NOT to use spacers if I can)? Thanks guys for all the help
My front driveshaft setup is the same except with a 242 transfer case. My rezeppa joint failed after 25k miles with this lift, it had 136k on it by that point so maybe it would have failed by then anyway. I didn't wait for it to completely disintegrate though, there was a vibration on the highway and upon looking further found a broken boot with grease thrown about. If you have the V8 your driveshaft will be shorter since the transfer case is closer to the front with that engine. I'd suggest changing out your transfer case yoke and swapping in a double cardan driveshaft. With the V8 you can just buy those used or rebuilt, for the 4.0 buy a V8 ZJ double cardan from the junkyard. I have purchase my new yoke and just need to pick up a junkyard driveshaft.
Upside is offline   Reply With Quote Quick reply to this message
Unread 04-14-2014, 01:50 PM   #595
yellowismellow
Custom User Title
My jeep is a 4.0 with a 247 case. I should've mentioned that. So what is involved in changing to a dc style shaft up front?
I've pulled 231 cases apart many times, but never a 247. How does the front yoke attach?
2006 TJ Sport
Unread 04-14-2014, 01:59 PM   #596
Upside
The yoke has a nut in the center, zip it off with an impact wrench and then install the new u-joint style yoke. I would install a new seal at this time. I need to order my seal and do the install myself.
The nut is 28mm and torque spec is 90-130 ft lbs according to the shop manual.
Unread 04-14-2014, 02:20 PM   #597
yellowismellow
Custom User Title
Awesome news! Is the rear the same? That seal leaks so I need to pick that up.
2006 TJ Sport
Unread 04-14-2014, 02:58 PM   #598
Thomahawk
Thomahawk's Avatar
Google how to fix 247 transfer case, then you Will find a full Go thrue with pics and everything, looked into it before, but never did it, looked doable though.
Good luck!
Edit, found it for ya, http://www.ehow.com/how_2179550_disa...se.html#page=3
Unread 09-11-2014, 12:35 PM   #599
wxmanWJ
Hey everyone. Just thought I'd provide a little tidbit of information I picked up. I am (still) debating what lift I want and I was researching BDS vs. Fat Bob's springs. I sent a question to Fat Bob's about their spring rates and they responded saying that their springs are
"...12 lbs heavier than the stock spring rate."
Now, I'm not entirely sure what the stock spring rate is but let's call it 180-190. This puts us somewhere around the 200 lb rate for the Fat Bob's springs, vs. the claimed 240 lb rate by BDS earlier in this thread. So something to keep in mind for those shopping- the Fat Bob's springs do indeed appear to have a lower spring rate than the BDS springs based on what I was able to find out.
My "stocker" build thread: http://www.jeepforum.com/forum/f310/my-first-jeep-owning-adventure-1532212
wxmanWJ is offline   Reply With Quote Quick reply to this message
Unread 10-29-2014, 12:54 PM   #600
TontoKowalski
Wj
Are the MOOG Spring Isolators garbage then?
Seems like people here prefer the RAYBETOS for their WJ's...or did I read that incorrectly?
Bones heal chicks dig scars & the USA has the best doctor-to-daredevil ratio in the world.
TontoKowalski is offline   Reply With Quote Quick reply to this message
