The Comprehensive BDS/FatBob's 2" Lift Thread - Page 11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > The Comprehensive BDS/FatBob's 2" Lift Thread
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 06-13-2011, 02:29 PM   #151
sherker55
been emailing him, he isn't out of business: here is his email amermold@bellsouth.net
he has:
3/4" and 2 1/2" front and rear
1 3/4" rear spacer
Originally Posted by HaViiK View Post
Send me the number, she can take a ride in a real jeep
Originally Posted by WillMcD View Post
She said call her when your over 4"
sherker55 is offline   Reply With Quote Quick reply to this message
Unread 06-13-2011, 03:05 PM   #152
billzcat1
Chicken in a Turkey Suit
2003 WJ
Cool. I had heard from several people that he wasn't responding to email.
billzcat1 is offline   Reply With Quote Quick reply to this message
Unread 06-26-2011, 01:20 PM   #153
phoenixzro
Is there a specific reason you bought 8 spring isolators instead of four?
phoenixzro is offline   Reply With Quote Quick reply to this message
Unread 06-26-2011, 01:21 PM   #154
narnwv
narnwv's Avatar
Top and bottom of each spring.
Sent from my Atari 2600
~Aaron
narnwv is offline   Reply With Quote Quick reply to this message
Unread 06-26-2011, 01:21 PM   #155
billzcat1
2003 WJ
Because there are isolators on top and bottom of each spring.
[edit] Narn beat me to it
Unread 08-19-2011, 01:08 PM   #156
ARdirty
Hey guys, I have a 2 inch BB and hydros and was wondering if anyone thinks that some fresh stock springs and new isolaters would give me anymore lift. Say around maybe half an inch? put my BB on my 99' and im just thinking that these springs have to be sagging a good bit after nearly 12 years. If you find any springs like these let me know!
ARdirty is offline   Reply With Quote Quick reply to this message
Unread 08-19-2011, 01:30 PM   #157
Upside
Originally Posted by n666z
I just ordered 2 sets of them one for the front and one for the rear, is it possible to just use a smaller bolt you think instead of changing the sleeve? I have the eibach sway bar ready to install but i'm gonna wait for the rear end links to get here before I toss it in. I guess we'll find out
Have you received your links yet? I could get my links sleeved and extended but I'd rather replace gem with new hardware after 110K of use.
Upside is offline   Reply With Quote Quick reply to this message
Unread 08-19-2011, 01:51 PM   #158
billzcat1
2003 WJ
Well, what's your hub-to-fender now?
Unread 08-19-2011, 02:33 PM   #159
Moab4Life
No reply to my emails... its been several days...
Moab4Life is offline   Reply With Quote Quick reply to this message
Unread 08-19-2011, 02:38 PM   #160
ARdirty
Currently the jeep is sitting in a library parking lot broke down on me while i was driving it last night. Let you know when i can
Unread 08-19-2011, 02:41 PM   #161
billzcat1
2003 WJ
???? Who are you talking to/about?
Unread 08-20-2011, 04:04 PM   #162
Moab4Life
he has:
1 3/4" rear spacer
This....
Unread 09-05-2011, 02:34 PM   #163
Upside
Just had the isolators and springs done on the WJ. It lifted quite a bit as the originals were shot!
The Monroe Reflex shocks aren't really up to the task and I see what you mean about the rear sway bar linkage issue. I think I'm going to make some 2" drop brackets for the attachment to the body so factory WJ linkages can be used. Also I think a set of the 5100s would really make the ride what I'm looking for.
Unread 09-05-2011, 11:54 PM   #164
billzcat1
2003 WJ
There's only so much you can do for ride quality when you have solid axles. But yeah, proper sway bar geometry really helps. Re-doing my front RC disconnects (a whole nother story) really helped. And the Bilsteins can't hurt either.
Occasionally, people say they don't like them. They will allow a lot of travel if you are driving with no sway bar at all and their initial response with the 5100s is a little soft. With HDs, the initial response is firmer. With most of the twin tubes, they are firm all the time and that's what some people prefer.
Unread 09-08-2011, 07:11 PM   #165
sherker55
I finally have proper sized endlinks on my sways, and it has made a complete difference in ride quality. factory end links with OME HD springs (about 3" of lift) is a big no-no for ride comfort. so I now have IRO endlinks for 3" front and rear, and addco front and rear sway bars...I do however have 3/4" spacers in the rear (from amermold@bellsouth.net ) because the OME springs are supposed to "level out" the wj, but I felt like I was looking "up" the hood to the road, instead of looking down it. I think it should be a little higher in the rear anyway.
I actually redid the whole front end really...IRO endlinks, addco swaybar, all 4 TRE's (MOOG), new "red" bushings from JKS for the adjustable TB (mine came with the old black ones for some reason, HUGE difference with the new red ones), IRO bar pin elimators, new isolators up top (lowers were done @ install a year ago)...now I just need an alignment, and I'm good to go!
