Cold Weather Brakes?? - JeepForum.com
post #1 of 6 Old 09-19-2013, 06:59 PM Thread Starter
Brakeman62
I have a 2001 WJ Laredo 4.0. When I first start it on a cold morning the brake peddle is stiff and goes nearly to the floor. If I pump the peddle it will start to build back up. As the truck warms up, the brake peddle loosens up and the brakes get back to normal.
Any ideas??? Thanks!!
Brakeman62 is offline
post #2 of 6 Old 09-19-2013, 09:53 PM
asatxj
asatxj's Avatar
If the PEDAL goes to the floor when cold and gets better, I would take a look at your booster and the vac. plumbing for it. Might have a slow leak that the system can overcome and pressurize when you get going. Are your brakes mushy all the time? when did you do your last brake job?
Jeep Fleet Maintenance Director
'00 WJ, son's Jeep,'01 WJ mine, '04 TJ, brother's Jeep,00 WJ daughter's
Maintain your stuff so you don't have to fix your junk
ASAT= All Season All Terrain
asatxj is offline
post #3 of 6 Old 09-20-2013, 02:44 AM
sprocket1200
Try new fluid with turkey baster method. Cheap and easy.
Ours improved noticeably after doing this and it was already good then!
sprocket1200 is offline
post #4 of 6 Old 09-20-2013, 10:37 AM Thread Starter
Brakeman62
Thanks for the reply!! Brakes are not mushy all the time, only when I start it in cold weather. I just replaced both front and back brakes.
post #5 of 6 Old 09-20-2013, 11:25 AM
Merc1973
And the Master cylinder.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #6 of 6 Old 09-20-2013, 09:36 PM
asatxj
asatxj's Avatar
Only when cold sounds like maybe some moisture in the system, water will condense when it's cold and give you a "water bubble" that will get somewhat dispersed when it gets warmed up. Still somewhat spongy though. I'd do the turkey baster method and then bleed the system as step 1. If there is no change I'd replace the booster (I have two good used ones btw) and last do the MC. Unless you can find a used MC/Booster combo for cheap and do both.
asatxj is offline
