Cold Air? Where? Or is it all Hot Air? - JeepForum.com
post #1 of 3 Old 03-22-2010, 04:40 AM Thread Starter
Maaark65
Ok, someone please sort me out once and for all on cold air intakes PLEEEEAASE. Sorry for the pun, but is it all a bunch of hot air?..i mean, if the intake is in the engine bay, and open, unlike the exisitng filter in my Overland which is at least in a plastic box, how can it be a cold air intake? take these examples...advertised as a cold air intakes:
Mopar - Performance - Trail - Cold Air Intake Systems
Jeep Grand Cherokee K&N 57 Generation II Cold Air Intake - 1999-2004 Jeep Grand Cherokee - K&N K335715131
surely, they are HOTAIR INTAKES...I mean, theres no cold air under the hood of my Overland !!!..at least this one, doesnt use the term "cold air"....but is called a "performance intake":
57-1513-1 - K&N 57 Series FIPK, Performance Intake Kit
Arent they the same product?
So, is it all hot air? I've seen v8 jeep drivers on the internet listing cold air as one of their mods.......and if it is as i suspect all hot air, does the performance intake actually improve performance?
Maaark65 is offline
post #2 of 3 Old 03-22-2010, 06:08 AM
Zoramac
2014 KL Cherokee
You are correct, the "cold air" is a misnomer, same as cars that have "ram air", they are just better flowing systems (usually). Even routing a direct line to the outside will at most give ambient air temp. they do offer a slight increase due to a better air path, (better filter and getting rid of the silencer helps). I know that in the gto and fbody forums these issues have been beaten to death multiple times so im assuming the same rules of physics apply to jeeps as well.
Zoramac is offline
post #3 of 3 Old 03-22-2010, 07:34 AM
rm2001wj
rm2001wj's Avatar
Under ordinary driving conditions, the computer is in closed loop mode and using O2 sensor feed back, it keeps the mixture close to 14.7:1 regardless of the intake air temp. The throttle is in full control of the power being produced by the engine, because it controls the amount of air getting into the engine.
Under wide open throttle (WOT), computer in open loop mode, the throttle can no longer control the power and cooler air can make a some difference in power production. The computer still monitors the intake air temp with the IAT sensor. It knows that cooler air is more dense and so it injects the additional fuel needed to match the denser cooler air. More power will be produced by burning the additional fuel. Obviously, no cool air intake can reduce the intake air temp lower that the outside temp.
Keep in mind the the effectiveness of the intake depends on WOT operation, that is, the accelerator pedal is on the floor. With normal part throttle operation the cool air intake is worthless.
rm2001wj is offline
CRD: Cold Weather, Cold Truck, Chirping? Jscheier WK Grand Cherokee & XK Commander Forum 19 02-04-2010 01:47 PM
COLD air intake, I mean COLD! Jeepster24 ZJ Grand Cherokee Forum 29 10-17-2009 11:55 PM
AC and Heater problem. Hot is cold and cold is hot? aerospace ZJ Grand Cherokee Forum 4 06-19-2009 05:28 PM
AC Cold but not Cold Enough. How to add R134 ScotZ ZJ Grand Cherokee Forum 3 05-21-2009 10:08 PM
Cold oh so Cold no Heat - mostly not blend door. Jawa78 ZJ Grand Cherokee Forum 0 03-14-2008 05:53 AM
