Cold air stock - JeepForum.com
post #1 of 3 Old 06-08-2013, 07:07 AM Thread Starter
bushido7seven
Cold air stock
What if I cut the tube to allow more air get in . Also what if I open a second hole that connects to the grill with a tube ( I hope you guys understand what I am going for) .
bushido7seven is offline
post #2 of 3 Old 06-08-2013, 07:55 AM
alfaitalia
I did just that.....see one of my old threads. Chopped off the pipe at a 45 degree angle in the air box and the flap that goes across the intake pipe by the grille. Did not notice any diff on fuel consumption and only a slight difference in throttle responce at the lowest revs before the turbo starts boosting (CRD). Was an interesting experiment but not a lot was gained.....although it has a very slightly louder intake noise.
Found link:
http://www.jeepforum.com/forum/f310/...iment-1517372/
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #3 of 3 Old 06-08-2013, 09:02 AM Thread Starter
bushido7seven
Sounds great ! I will be doing this soon but with some tweaks.
