Cold Air Intake? - JeepForum.com
post #1 of 21 Old 01-24-2012, 08:16 PM Thread Starter
handy3030
2004 FSJ Cherokee
Cold Air Intake?
Does anyone have any recommendations on a nice and good cold air intake for a 2004 grand cherokee 4.0 LS
handy3030 is offline
post #2 of 21 Old 01-24-2012, 08:25 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
No such thing. You can get a k&n or make your own, but its going to be a warm air intake and wont do much if anything at all as far as performance.
~James
ezflip is offline
post #3 of 21 Old 01-24-2012, 08:57 PM
thisguyhasadd2
i run dry ice in my stock airbox
2002 Overland - 4" rc -255/75/17/Jk Moabs
1982 Yamaha XT200J- dead, rebuild winter
Colorado Jeep Club Member#259
thisguyhasadd2 is offline
post #4 of 21 Old 01-24-2012, 09:00 PM
pinky2252s
I thought about that for a second, thought it would work, but then i thought harder and realised that dry ice emits CO2, so... your engine most likely wouldnt even start. Hah.
Funny though.
pinky2252s is offline
post #5 of 21 Old 01-24-2012, 09:01 PM
peytonimor7
I've already got one of your quotes in my sig... you just keep em comin! LOL
l 04 WJ l OME HD+3/4" spacers l Bilstein 5100 l 245/70/17 Firestone M/Ts l IRO A-Arm & CAs F & R l
peytonimor7 is offline
post #6 of 21 Old 01-24-2012, 09:40 PM
WeThePeople408
Recently installed a K&N on my 4.0
http://s1068.photobucket.com/albums/...Engine%20Mods/
WeThePeople408 is offline
post #7 of 21 Old 01-24-2012, 10:05 PM
Voltage258
2003 WJ
I got a K&N and noticed a differance. And the sound is worth it alone. But im not sure how it will do in the 100 degree summers but i guess i will find out.
03 Grand Cherokee, 4inch Zone lift 15inch craiger soft 8's 31 inch duratracs nothing to special. SOLD
82 Grand Wagoneer Limited. Amc 360, Bridgstone MT's
Voltage258 is offline
post #8 of 21 Old 01-24-2012, 10:16 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
I have a K&N with a heat shield on my 4.7. According to my Ultragauge reader, the inlet air temperature is usually about five degrees warmer than it was with the stock box. I don't think 5*F would make that much of a difference, and it does sound a lot cooler... Just my $0.02
In the garage: M1 4bbl
McCloudsZJ is offline
post #9 of 21 Old 01-24-2012, 10:56 PM
mycreativename
So your new intake is warmer than the stock one or am I reading that wrong?
Also fun fact, whenever I read your name, I can just think "There can only be one" (Yes I know its spelled "MacLeod" in the Highlander series, still just makes me lol)
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #10 of 21 Old 01-24-2012, 11:42 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Also fun fact, whenever I read your name, I can just think "There can only be one" (Yes I know its MacLeod in the Highlander series, still just makes me lol)
Yes, you're reading it right. It's technically a FIPK (Fuel Injection Performance Kit or something like that). They're supposed to increase performance because they're "less restrictive" than the stock air box.
I don't know of any true cold air intakes out there for a WJ. A real cold air intake is supposed to pull cooler air from somewhere other than the engine bay.
An engine's potential to make power is a function of the temperature difference between the inlet and the combustion chamber (as well as a couple other things). If you can get cooler air in, or get the engine to burn hotter, there is a larger potential for power. Some math to prove it http://en.wikipedia.org/wiki/Otto_cycle
Bottom line up front, there may be power gains from the less restrictive air flow. There may be power lost to the smaller heat differential. You'll have people that will swear by both arguments. But, it sounds cool as hell.
Most CAI's are some variation of this--the air going into the engine is from outside of the engine bay and supposedly cooler:
A FIPK looks like this, with the inlet still inside of the engine bay:
post #11 of 21 Old 01-25-2012, 12:11 AM
mycreativename
Any chance of a video to show, or rather let us hear the difference in noise? I'm curious to what changes.
post #12 of 21 Old 01-25-2012, 12:28 AM
thisguyhasadd2
there is a loud suction and swoosh noise. as mccloud showed above if you could reroute where the air comes from that goes to filter it would be better. I like the FIPK to clear things up a bit and make it easier to do work. I got mine done for 15$ including filter. Really wouldn't want to spend the flow on the kits
peyton good stuff amigo. although i definitely did a triple take the first time i saw it!
post #13 of 21 Old 01-25-2012, 11:42 AM
pinky2252s
I'll just make my own... Haha. Maybe ill do a write up..
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
post #14 of 21 Old 01-25-2012, 01:38 PM
K10roc
I made mine and powder coated it when i port and polished and powder coated my throttle body. works great!!! wiht as much that is open under the filter keeps cool air coming in, i noticed much better throttle response, sounds cool, and a bit better gas milage
Joe K.
"if you can buy it, you can build it BETTER"!
2000 Jeep grand WJ limited, 245/75/16, Thrust 2 chamber muffler, 2in bb, rough country shocks, slotted and drilled rotors, Torqflo trans cooler, powder coated calipers, custom made CAI, K&N cone filter, ported and polished throttle body, Chip, Torqflo trans cooler, 6000k HID, PIAA fog, lots of powder coating and blacked out parts
K10roc is offline
post #15 of 21 Old 01-25-2012, 01:52 PM
1AAdam
thats pretty much what i have heard. it may help response just a little but the sound is the biggest difference.
Adam
1aauto.com
888-844-3393
1AAdam is offline
cold air intake Jrams513 WJ Grand Cherokee Forum 4 05-25-2011 04:27 PM
Cold Air intake Akjeep92 WJ Grand Cherokee Forum 11 05-08-2011 10:54 PM
Cold Air Intake and Cat back islandwheeler WJ Grand Cherokee Forum 3 10-19-2010 11:08 PM
Who has a cold air intake on their WJ 4.0L I6? steveridesli WJ Grand Cherokee Forum 8 04-23-2010 12:32 PM
