Coil Springs? - JeepForum.com
post #1 of 11 Old 02-03-2014, 09:03 PM Thread Starter
mamma_jm
Coil Springs?
I'm new to this and not very car savvy so bear with me please!
I just bought a used 2003 Grand Cherokee. I work in an office park with lots of speed bumps and everyday when I would drive over them, there would be this somewhat wretched sound coming from the front left wheel well. Never thought anything of it because it was only when I went over speed bumps.
Driving down the highway the other night, hit a pothole and now something is broken. Car pulls a little to the right and whenever making a sharp turn or going over a bump it makes an even worse sound, like a scraping or crunching. Not sure how else to describe it. I've been told it could be a few different things, snapped coil spring, shock absorber mounts or a blown strut. My husband and his friends are pretty good with cars in general so can someone tell me if this would be an easy fix or would I be better off going to a mechanic?
mamma_jm is offline
post #2 of 11 Old 02-03-2014, 11:10 PM
js12278
I am sure once they get under the WJ they should find the issue and should be able to fix it.
js12278 is offline
post #3 of 11 Old 02-04-2014, 09:41 AM
ChrisHager
Administrator
ChrisHager's Avatar
Could be a few things. I agree with js - someone needs to crawl under and look. Without doing that, we're all just guessing. If in doubt of the repair, a mechanic would be the safe choice.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #4 of 11 Old 02-04-2014, 02:00 PM
Jebby
pictures would help us but if your husband knows cars he will most likely find the issue quickly. shouldn't be to hard to spot if something has broken free
Jebby is offline
post #5 of 11 Old 02-06-2014, 01:19 PM Thread Starter
mamma_jm
Thanks for the responses. We brought it to the guy I bought it from today. On the phone he was trying to tell me it was my own fault and basically **** out of luck but I've barely had the car for a month, hopefully he'll fix it for me.
mamma_jm is offline
post #6 of 11 Old 02-06-2014, 02:09 PM
mudpack
Your WJ does not have struts. A broken coil spring, depending on where it was broken, would not make the noise or cause a pull to the right, and/or would cause your WJ to sit unevenly. Broken shock absorber mount would be clanking all the time.
Sounds like bad suspension bushings or, more likely, bad tie rod ends to me.
mudpack is offline
post #7 of 11 Old 02-06-2014, 02:25 PM
ChrisHager
Administrator
ChrisHager's Avatar
...We brought it to the guy I bought it from today. On the phone he was trying to tell me it was my own fault and basically **** out of luck but I've barely had the car for a month, hopefully he'll fix it for me.
Huh? That seems like a bad idea. Is he a mechanic? Did you agree when you purchased it that he would take care of future issues?
If you constantly hit speed bumps and found something broke after hitting a pot hole after a MONTH of ownership, I'd have to agree that this is totally out of the previous owner's hands UNLESS he knew there was something wrong and agreed before selling that he'd take care of it.
I'm not trying to be rude but it seems strange you expected the previous owner to take care of the problem. Better yet, it seems strange that you'd even bother to call the previous owner, let alone let said PO fix the issue...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #8 of 11 Old 02-06-2014, 03:04 PM Thread Starter
mamma_jm
I bought it from a car dealer/mechanic. The lemon law in Mass would've covered it if it had happened before 1/24. I called the guy hoping he'd help me out considering it was just 6 days over the 30. My husband said whatever it was that broke, should not have broken so easily.
It ended up being a mount connected to the sway bar, or something along those lines. He just welded it back on.
mamma_jm is offline
post #9 of 11 Old 02-06-2014, 03:08 PM
ChrisHager
Administrator
ChrisHager's Avatar
That makes so much more sense now!
Interesting. Sound like perhaps it broke where it mounts to the axle (see pic below - the vertical bar that mounts right in front of the spring). Did you check the underside of the vehicle for rust before you bought it?
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #10 of 11 Old 02-06-2014, 03:20 PM
Thomahawk
Broken endlink mount at front lower spring perch, sounds familiar, Seen it before
Buildthread
Thomahawk is offline
post #11 of 11 Old 02-06-2014, 07:47 PM
2ndhandWJman
2ndhandWJman is offline
