Coil Spring Retainers - JeepForum.com
post #1 of 8 Old 10-12-2010, 03:53 PM Thread Starter
smunns
After losing a coil spring on an obstacle this past weekend, I want to fab up some retainers.
Would something like this be enough?
Or do I want to go with this style?
smunns is offline
post #2 of 8 Old 10-12-2010, 06:49 PM
StrokedWJ
StrokedWJ's Avatar
Either one will work. The top type will capture the coil. You'll want to use them on both the top and bottom of each coil. The bottom version will let the coil come off of the top perch but it won't let it fall out. When you come back down it will help guide the spring back onto the post.
If you have a welder or know someone who can weld, a piece of 2.5" exhaust pipe welded to the top post serves the same purpose for < $10.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #3 of 8 Old 10-12-2010, 06:57 PM
skullysXJ
I would go with a set of both. I have the 2nd of the two and I've never lost one but it will sometimes not seat right on the bottom rubber seat. I plan to fab up a set of the first to put on the bottom.
~KADE~ kool kid klub #1
08 JKU Rubicon
skullysXJ is offline
post #4 of 8 Old 10-12-2010, 07:04 PM Thread Starter
smunns
Sweet, I'll just bend up some flat stock for the bottoms, and weld in some exhaust pipe up top. Thanks for the tip!
smunns is offline
post #5 of 8 Old 02-19-2011, 07:20 PM
sinbad85
I just lost my front spring today, does anyone use spring retainers for the rear or is that not a problem?
2001 WJ 4.7L-selec-trac/4.5" Teraflex springs\IRO Long arms\Iro adj rear LCA/Bilstien 5100 series shocks/ IRO steering Equalizer/|265/75/16 Goodyear Dura-Tracs on Stock rims\Rear Tube Bumper with carrier|sliders|mopar skids.
sinbad85 is offline
post #6 of 8 Old 02-19-2011, 07:53 PM
orb
2003 WJ
Would also love to know this.
And where can I get the top ones? What do they bolt to?
2003 4.0L, OME HD Springs, OME Nitro Shocks, Rancho SS, 265/70R16 General Grabber AT2s
orb is offline
post #7 of 8 Old 02-19-2011, 08:50 PM
skullysXJ
Ironrockoffroad sells some top ones. They just thread into the spring perch
08 JKU Rubicon
post #8 of 8 Old 02-20-2011, 12:59 AM
huntandfish
IRO sells both styles pictured above. the clip ones are about 20$ and the upper ones are about $50. IRO says that either one will help retain the spring but for best results use both.
I dont see the rear being a problem for most people who keep the rear sway bar connected to keep the body roll down. Even if you did disco the rear sway bar you would probably need aftermarket rear control arms to loose a rear coil.
1992 YJ 2.5 SOLD
2004 Grand Cherokee Special Edition 4.0
IRO 3",JKS BPE's,DoetschTech8000's,Tenneco SS,Cooper Discoverer STT's 245-75R16,RC wheel spacers,SSBC Slotted Rotors, IRO Prem-sliders...
A great place for outdoorsmen in the NW.
Member Screen name- addicted
huntandfish is offline
AC magnetic coil replacement laybackman WJ Grand Cherokee Forum 1 08-15-2012 10:04 AM
wj coil pack 4.0 rda616 WJ Grand Cherokee Forum 6 12-15-2010 01:39 PM
Help Coil Spring removal and Installation... blazepsi WJ Grand Cherokee Forum 13 10-12-2010 08:33 AM
rear coil iso STINGN WJ Grand Cherokee Forum 0 03-29-2010 10:56 PM
Overland Quadra Coil? DaveFL WJ Grand Cherokee Forum 0 08-15-2003 08:54 AM
