Coil spacers - JeepForum.com
post #1 of 3 Old 08-19-2014, 11:44 AM Thread Starter
scurtis
Coil spacers
Has anyone used the 3/4 spacers on the front ? If so after you put them in what exactly holds the spring in at the top ?
SKEETER
scurtis is offline
post #2 of 3 Old 08-19-2014, 12:40 PM
alfaitalia
The weight of the Jeep.....same as before you put the spacers in! Nothing physically clamps the springs in place, top or bottom, which is why you can drop a spring if you over flex off road.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #3 of 3 Old 08-19-2014, 03:10 PM
mycreativename
Many of us have them to balance out the "rake" of the Jeep. As alfa said, they're just held in by the spring and the upper isolator. The way it goes bottom to top is, bottom isolator, spring, upper isolator, 3/4 in spacer.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
