Codes P0303 & P0304 - JeepForum.com
post #1 of 10 Old 02-15-2011, 07:20 PM Thread Starter
lovemy3
Wj Codes P0303 & P0304
New to the jeep world and just need alittle help.....
Just brought a 1999 Jeep Cherokee Laredo 4.0...Changed the plugs & coil pack but still has ruff idol. Any ideas where to go next?
Any help would be appreciated. Thanks in advance
lovemy3 is offline
post #2 of 10 Old 02-15-2011, 08:35 PM
oakmckinley
Those codes are for a cylinder misfire in #3 and 4. There is a heat soak problem that happens and can cause cylinder misfire. There a some threads on this. I think there is something you can buy that insulates it.
Good luck.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #3 of 10 Old 02-15-2011, 08:39 PM
GilaMtnJeep
GilaMtnJeep's Avatar
I had this problem in the past. Read this post.
http://www.jeepforum.com/forum/f9/03...en-hot-607283/
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #4 of 10 Old 02-15-2011, 10:32 PM
bigchevyman24
bigchevyman24's Avatar
I have the p0304 at all times, not just when the engine is hot. I have new plugs and coil rail also. The next thing I'm replacing is the injector on that cylinder. I'm hoping it fixes it. If not, I'm gonna put a match to it lol... I have also read that it could be the gapping on the plugs, fuel filter, the heatsink issue(you should have a heatmat on the top of the intake in between the injectors and the intake itself), and you may also want to clean the throttle body. My bet would be fuel injectors are probably clogged or have gunk in them. Have you ran any fuel injector cleaner lately?
CURRENT: 2001 WJ V8 LIMITED - Quadratrac, 60th anniversary, Fat Bob's 2.5/2 lift, HID's, roof rack, 31" Rugged Terrains, 5k lb Curt Hitch
SOLD: 2000 WJ 2WD CONVERTED TO 4X4, 97 TJ ON 35'S, 95 XJ ON 33'S
bigchevyman24 is offline
post #5 of 10 Old 02-16-2011, 07:54 AM Thread Starter
lovemy3
Thanks everyone for your help. Yes Ive ran (1) bottle of injector cleaner and have another in the jeep to run. I was talking with a guy last night at autozone...(one that seemed like he knew alittle..not like most there) said he would test pressure of injectors first then go from there. Thanks everyone for the links to all the fourms..I've did alittle bit of reading and it's helped.
Sorry for being "clueless"....everyone just thinks Im your avarage "blonde". LoL.
Thanks for your help again!
lovemy3 is offline
post #6 of 10 Old 07-25-2011, 06:22 PM
02jeepAZ
I'm sorry to bring the thread up again, but i'm currently am having the same problem of cylinder 3 misfire on my 02 jeep grand cherokee 4.7L , i drove the car for about 2 hours straight on saturday and parked the car that afternoon, when attempting to turn it on on sunday, the car only clicks when turning the key. i have read several threads and googled quite a bit, some say sparkplugs or coils can be the problem or even the injector, i'm currenty tight on money so my question is where is it best to start from as far as replacing and/or checking for problems on my car?
02jeepAZ is offline
post #7 of 10 Old 07-25-2011, 11:28 PM
02jeepAZ
anybody???help would be greatly appreciated
02jeepAZ is offline
post #8 of 10 Old 07-26-2011, 06:55 AM
tsconver
2003 WJ
move the coil pack to a different cylinder and see if the miss fire follows it. If it does you have a bad coil. If it does not move then try moving the injector to a different cylinder, if the code moves then it is a bad injector. You running the recommended plugs, I know the 4.7 is pretty sensitive to plugs.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #9 of 10 Old 07-26-2011, 07:17 AM
ChrisHager
Administrator
ChrisHager's Avatar
...when attempting to turn it on on sunday, the car only clicks when turning the key...
This line right here tells me it's something electrical or battery related. Does your vehicle start? If it literally just clicks when you turn the key over, I'd start by checking/charging your battery.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #10 of 10 Old 07-27-2011, 06:18 PM
02jeepAZ
Wj
battery checked out fine when i took it to autozone, check starter relay fuse in the inside fuse box under the steering wheel and then checked outside fuse box in engine bay, checked all fuses and relays that i thought would be related to my problem, my next question is if the starter would be the problem, when turning the key and hearing the "click" sound is that my starter clicking? or does the click itself not make a difference and everything checking out fine would lead to possibly being the starter?
02jeepAZ is offline
Help with codes Bobbis WJ Grand Cherokee Forum 2 01-25-2011 07:44 AM
Just got 2 MIL codes jeep1987 WJ Grand Cherokee Forum 4 01-14-2011 08:35 PM
azc codes CoolGuyDave WJ Grand Cherokee Forum 2 10-26-2010 08:41 AM
Help!!! (ABS codes) ljhopp WJ Grand Cherokee Forum 9 07-08-2010 12:25 PM
Code P0304?????? What do I do????? budro69 WJ Grand Cherokee Forum 7 05-17-2010 04:57 AM
