code reader - JeepForum.com
post #1 of 9 Old 12-20-2011, 10:13 PM Thread Starter
meopilite
code reader
Thinking of buying a code reader. Never used one. I see WalMart has them. I dont want to spend a lot. Maybe around $100. I've heard some models can tell you gas mileage and such......
Any advice before buying one??
meopilite is offline
post #2 of 9 Old 12-21-2011, 08:01 AM
Double E
Double E's Avatar
You want something beyond the WJ already being able to give you the codes for free?
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 9 Old 12-21-2011, 08:31 AM
BigBeefy
Getting codes, as mentioned above, is free on the WJ.
Turn key to on-off, on-off, on and watch your odometer display the codes.
If you want something that will give you real time data, youre going to spend more than 100 bucks.
The el-cheapos from wally world will just give you a code read-out and possible even the source/problem of the code.
Check your local auto parts store for a scanner that gives you live data read-outs.
2004 Overland, 75k miles, 4.7L H.O.
1997 ZJ TSi, 265k miles, 4.0 I6
BigBeefy is offline
post #4 of 9 Old 12-21-2011, 08:36 AM
MadderThanMax
Wj
Don't! Unless of course you wanna pay out all your Christmas bonus on one. There's something that Chrysler/Jeep put in that doesn't allow a scanner to communicate to OBDII on the WJ vehicles. I've got two - a cheapie and an expensive one and both come up "No Codes" despite there being some displayed on the dashboard display. You can't erase them either. So in short a waste of space and $$ IMHO. Best get a friend that works with a dealer or the dealer to remove them....
MadderThanMax is offline
post #5 of 9 Old 12-21-2011, 08:40 AM
BigBeefy
If you have an export model, which I am sure you do, the VIN sequences are somewhat different and the scanners dont always recognize them.
I have used many over the counter scanners that work as advertised.
BigBeefy is offline
post #6 of 9 Old 12-21-2011, 08:42 AM
ChrisHager
Administrator
ChrisHager's Avatar
If you have an iPhone or Android phone, you can buy Torque for $5, the OBDII WIFI dongle for $150 or OBDII Bluetooth dongle for $100 (there are MUCH cheaper China made ones for like $30 that some seem to have luck with), and a $5 window suction cup to hold your phone. Just around $100 get's you a code reader, real time data, and allows you to erase codes.
http://www.plxkiwi.com/
Edit: I have one for my WJ and it works well. My mom also has one for her Isuzu Trooper and again, it works as it should.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #7 of 9 Old 12-21-2011, 11:49 AM
Merc1973
I have the same and it works well.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #8 of 9 Old 12-21-2011, 12:46 PM
indept
I have this one that I keep in the jeep, works fine, got it for 39 bucks, they run sales all the time
http://www.harborfreight.com/can-obd...enu-98568.html
I also got this one on ebay for about 150, it reads & clears ABS codes too
http://www.actron.com/product_detail.php?pid=16364
2000 WJ 4.0L 42RE 242 TC
190,091 miles & counting
indept is offline
post #9 of 9 Old 12-21-2011, 01:21 PM Thread Starter
meopilite
Newer ones are suppose to work with any vehicle '96 and up.
CEL - Code Help Please! GrandAZ WJ Grand Cherokee Forum 9 07-05-2011 12:43 PM
TPS/Pedal position sensor code? Replaced TPS, code still shows? Mike94ZLT1 WJ Grand Cherokee Forum 1 06-06-2011 01:00 AM
Code help!! theskier74 WJ Grand Cherokee Forum 4 02-20-2011 08:16 PM
Code Reader Question??? cody_gs1 WJ Grand Cherokee Forum 5 10-11-2010 12:41 AM
03wj code reader. what kind? ronsaun WJ Grand Cherokee Forum 5 03-18-2010 11:10 AM
