code p1391 and misfiring - JeepForum.com
post #1 of 4 Old 12-27-2013, 06:41 PM Thread Starter
lemiller
Hey everyone,
I have just started having in issue with my WJ. I drove home to MI from IL (4hr trip) with no issues and two days later i got in and my jeep was running real rough and "chugging" Code p1391 came up.
Now this isn't the first time i have this code, i have already replaced toe cam and crank position senors 3 times (in about a year) first two with autozone sensors and 3rd with Mopar.
I just changed the camshaft position sensor out again (4th time) with a Mopar part. After replacing it is still running real rough.
Now my question is, what else could be causing this issue? I have been reading and have seen talk of bad timing chains, or tone wheels etc.. How would i check for this? Any help diagnosing this problem would be great. I need to be back to IL by the 30th, so need to figure this out ASAP.
thanks in advance to everyone.
lemiller is offline
post #2 of 4 Old 12-27-2013, 07:21 PM Thread Starter
lemiller
update, also have code P0320 showing. Which is crank position sensor. Is there anyway to test the sensor before replacing? Also how would i go about testing the harness/ connector for a short? Seeing as this is my 3rd sensor I'm thinking maybe an electrical problem with the harness or the connector.
lemiller is offline
post #3 of 4 Old 12-27-2013, 07:24 PM
00jeepthing
mine was doing the same thing. i believe that it was that code p1391 it was throwing. i have a 4.0 and had a bad coil strip. it was around 100.00 for all new coils. they come as one unit. problem fixed.
00jeepthing is offline
post #4 of 4 Old 01-04-2014, 08:39 AM
Skortch311
Bump.
I have the same problem/codes... Crank sensor and all three coils. I had the dealer replace just the crank sensor, it didn't do s***.
STAY ARMY STAY AIRBORNE
Skortch311 is offline
