code p0740 - JeepForum.com
post #1 of 8 Old 12-10-2011, 10:43 AM Thread Starter
gilortiz316
Wj code p0740
Help!!! I just bought a 2001 lerado and i hate it to be a lemon. The check engine light went on and this code came out i would like to know if any one has had this issue or how i can fix it... Thank you for your responds...
gilortiz316 is offline
post #2 of 8 Old 12-10-2011, 11:23 AM
drrm123
1994 ZJ
I have same problem. Looking for a link to repair manual for a 42re. Do you ave a 4.7 or 4.0? Trans are different. TCC lockup trouble could be valve stuck, solenoid, or bad convertor.
2001 Jeep Grand Cherokee Laredo 6 cylinder Selectrac
$2400 installed new radiator 1 window regulator 2 oxygen sensors
drrm123 is offline
post #3 of 8 Old 12-10-2011, 02:25 PM
Double E
Double E's Avatar
Try this?
http://www.jeepforum.com/forum/f13/s...ailure-561977/
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #4 of 8 Old 12-12-2011, 10:52 AM Thread Starter
gilortiz316
i have a 4.0 engine and thanks guys will do
post #5 of 8 Old 12-12-2011, 01:49 PM
drwolcot
Same issue on my 2002..... solenoid has been replaced previously and so has the speed sensors. All that is left is the torque converter. My local Jeep dealer said they wanted to replace the torque converter and rebuild the tranny. I'm going to let them cause I have it on warranty. Otherwise just a new converter should do it for you
2002 WJ Overland | 4.7 H.O. | Clayton 6in LA | LSR Bumper | JKS discos | JKS Track Bar | KOR SS | BFG KM2's 285/75/17 | Carolina Front/Rear Driveshaft | Quadradrive | 125k Miles
RIP
|4.7 | 242HD | 2WD-->4WD Conversion | Vari-Lock front D30 | D44a Aussie Locker | Hybrid RCX 4in + BB | IronMan FUCA's | D30 Solid Diff Cover | Carolina Front Driveshaft | JCR Stage 3 Sliders | E-Fan Conversion | Hard-KOR SS|
2003 WJ Overland - SOLD
drwolcot is offline
post #6 of 8 Old 12-12-2011, 05:15 PM Thread Starter
gilortiz316
how much is that ruffly if you had to pay???
post #7 of 8 Old 12-12-2011, 05:17 PM
drwolcot
I haven't done it yet. Should be this week getting it done. I have a warranty though so it isn't going to cost me anything. If all that is wrong is the torque converter you don't need a transmission rebuild. They said they wanted to do one so I am not complaining with 117k miles.
RIP
drwolcot is offline
post #8 of 8 Old 12-13-2011, 03:28 PM Thread Starter
gilortiz316
oh ok cool thanks alot. ill look into that
P0740 Transmission Replacement Bill03 WJ Grand Cherokee Forum 7 10-21-2015 10:26 AM
Check Engine Light: P0740 fredimac WJ Grand Cherokee Forum 7 04-01-2012 04:33 PM
Very Sudden Transmission Issue (P0740) JRT403 WJ Grand Cherokee Forum 3 10-12-2011 09:04 PM
TPS/Pedal position sensor code? Replaced TPS, code still shows? Mike94ZLT1 WJ Grand Cherokee Forum 1 06-06-2011 12:00 AM
The dreaded P0740 solved Maugli WJ Grand Cherokee Forum 0 10-15-2010 08:32 PM
