Code P0725 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Code P0725
The Boss is away but Erin is here to STAY with a F.Y.S. SaIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 12-21-2010, 06:37 PM   #1
cb0y1
Code P0725
Since I got my jeep I've been fighting with the tranny going into limp mode and getting p0725. So far I've replaced the Crank Pos Sensor and the Trans input speed sensor, Disconnected and replugged the TCM and ECM, ran out the wires looking for a short while moving them around and found nothing. For a while, 2000mi the problem went away. Today it came back. I'm guessing looking at the wiring diagrams one side of the sensor goes to ground, I just don't know where. I'm sure someone else has had this problem. Is there an area of the harness known for rubbing on the engine and causing a short?
thanks
cb0y1 is offline   Reply With Quote Quick reply to this message
Unread 12-22-2010, 02:43 PM   #2
Double E
2000 Laredo V8
Double E's Avatar
Were both speed sensors checked? How many miles total?
This may need the trans code read by a scanner to see the failure in action rather than the resulting code.
2000 Laredo 4.7L Selec-Trac. 177K miles, Leather, 245 tires, tow package, crappy CD changer, full size spare, roof cross-rails & sunroof.
Changes & fixes: Rear Addco sway bar & greasble bushings, upgraded headlights, upgraded tail lights, new hood struts (replaced 2X), new rear hatchglass struts, new radiator (replaced 3X), new oil pressure sending unit (replaced 4X), 2 new speed sensors, 2 new door lock actuators, new ignition key cylinder, chrome front tow hooks, Mobil 1 Synthetic 5/30, Purolator Pure One oil filter, EBC slotted & dimpled rotors, EBC Greenstuff pads, new front shocks (replaced 3X), new rear shocks (replaced 2X), new IRO steering stabilizer, new timing chain cover, new water pump, thermostat, new thermostat housing, new high pressure power steering hose, Michelin-X radials, new sunroof assembly, new single-piece lug nuts, new exhaust manifold studs & gasket on driver's side, new Durango alternator. Jeepforum.com sticker, Visit cobaltboatsforum.com when you can!
Double E is offline   Reply With Quote Quick reply to this message
Unread 12-23-2010, 08:56 AM   #3
cb0y1
Speed sensors were not checked, but I didn't trash them either, coming up on 150000mi.
Unread 01-02-2013, 08:14 PM   #4
TOW_HOOK
1957 CJ3B
Wj
thanks
i'm going though he same thing, i have replaced, the cam, crank, and front trans speed sensor, and the probblem is back ? it seems to all go back to the crank sensor ? i will run down my wiring over the weekend, and printed out the pages from the fsm. back probe the crank sensor should have 4.8 to 5.2 volts, when the key is in the run posstion. any thing else is outta spec. remove ckp from the plug, make sure the plug has 4.5 volt t 5.0 volts.
57 3b classic krawler /93 xj r.i.p. / 95 yj daily driver / 02 wj wife's ride / 98 xj wanta be rock krawler
TOW_HOOK is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 10:19 AM   #5
99jgcl
Did you ever find a fix I'm have the same issue
99jgcl is offline   Reply With Quote Quick reply to this message
