Code P0304?????? What do I do????? - JeepForum.com
post #1 of 8 Old 05-13-2010, 04:09 PM Thread Starter
budro69
My wife's 03 GC, had a spurt of bad behavior this afternoon. She was merging on the freeway and it began to bog and almost stalled when she about hit 70. She pulled off and it idled normal but the engine light was flashing. She called me at work and I told her to turn it off and restart it, from there it ran fine but instead of flashing the engine light just stayed on. I had her check her codes and it came up with a P0304, I couldn't find the trouble code list but thanks to a previous post and ezflip I discovered it was a #4 cyl. misfire. I don't really know what could cause this and I was hoping someone on here would have some prior knowledge that might help me out. Any help or advice would be greatly appreciated. Thanks ahead of time.
budro69 is offline
post #2 of 8 Old 05-13-2010, 05:44 PM
mighttuss
Well for starter my friend you need a trun up! If you are not a do it your selfer,then maybe one of your friends is. If you lived in KY I would help you. Write down the make and model of your automoble take the list to your autoparts dealer and get Spark plugs/ Spark plug wires / R-cap and button. And yes I buy them all,cause you might have someone to tell you its your spark plugs and get home and change them and start you jeep and it do the same thing it did before. So why not change it all why your under the hood.
mighttuss is offline
post #3 of 8 Old 05-14-2010, 05:40 AM Thread Starter
budro69
I wouldn't say I am a mechanic by any means but spark plugs and wires I can usually handle. Although her car is different than anyone I have ever worked on. All the spark plugs are under this bar thing, and I see no distributor anywhere. I will take your advice and buy those things and change them, I'm fairly sure when I get them I will see where they go. Thanks for the advice mighttuss.
budro69 is offline
post #4 of 8 Old 05-14-2010, 09:52 AM
oldfamilyguy
The bar thing is the coil assembly, no distributor. take it off to get at the plugs. change them all if it hasn't been done in a while, especially look at #4 it might be obviuosly bad. There are other causes for a misfire, but go with the plugs first.
oldfamilyguy is offline
post #5 of 8 Old 05-14-2010, 11:38 AM
BigE3
Normally if its just one bad cylinder. You can be sure either a plug or wire is bad. I would check the wire 1st and see if you see any burn marks on the plastic. That will tell you that the insulator is bad and electricity is searching for the nearest ground.
I like my Jeep, just like my women. 'Loose and Flexible'
BigE3 is offline
post #6 of 8 Old 05-14-2010, 12:10 PM
rm2001wj
rm2001wj's Avatar
FYI for some of you posters; WJs (99 and later Grand Cherokees) use coil on plug ignition systems with no distributor and no spark plug wires. oldfamilyguy is right on target.
rm2001wj is offline
post #7 of 8 Old 05-17-2010, 04:54 AM Thread Starter
budro69
Thanks for the help, I am picking up new plugs this week
budro69 is offline
post #8 of 8 Old 05-17-2010, 04:57 AM
MacK
2015 JK Wrangler
My 2007 JK did the same error, P0306. I installed new spark plugs and wires and it has been great ever since. Even runs smoother.. good luck!
I don't want your d**n lemons! What the hell are these?! Demand to see life's manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I'm the man who's gonna burn your house down! WITH THE LEMONS! I'm gonna get my engineers to invent a combustible lemon that BURNS YOUR HOUSE DOWN!
Mango Tango 2010 JK Wrangler Rubicon
Silver 2000 TJ Wrangler Sport
The 2008 Jeep Wrangler is not so much an SUV as it is an experience. It's slow and loud, handles poorly, has crummy interior materials and features doors that provide virtually no crash protection. But when it comes to off-road performance, the Wrangler is simply the best choice available.
MacK is offline
Engine Code help- Code 11 athomas08 ZJ Grand Cherokee Forum 3 05-06-2009 11:56 PM
Emissions Light ON Code P0304 JoshuaDHarp ZJ Grand Cherokee Forum 15 09-09-2008 09:34 PM
Code 33 Dillonzj ZJ Grand Cherokee Forum 11 11-17-2007 04:17 PM
Code 37 sixtires58 ZJ Grand Cherokee Forum 4 06-26-2005 02:23 PM
Code 27 TheUser ZJ Grand Cherokee Forum 3 06-16-2005 01:28 PM
