Code P0158 - JeepForum.com
post #1 of 5 Old 12-22-2009, 03:43 PM Thread Starter
Apollo21
Code P0158
02 Overland WJ 105xxx
my WJ spit a code today
i figured out it was P0158 thanks to the on/off method that says, "Oxygen sensor input voltage maintained above normal operating range".
What does this mean? do i need to replace the O2 Sensor?
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #2 of 5 Old 12-23-2009, 12:40 PM Thread Starter
Apollo21
bump
i took it to auto zone and told the guy this he said its not the O2 Sensor but something causing the exhaust to be fuel rich thuse setting off the O2 sensor
An O2 sensor is a galvanic battery that provides the PCM with a voltage signal (0-1 volt) inversely proportional to the amount of oxygen in the exhaust. In other words, if the oxygen content is low, the voltage output is high; if the oxygen content is high the output voltage is low. The PCM uses this information to adjust injector pulse-width to achieve the 14.7–to–1 air/fuel ratio necessary for proper engine operation and to control
emissions
so what could cause fuel to not be combusted in the cylinder and thus fed into the exhuast? could it be the type of gas i put in? should i do new spark plugs?
any help is great
SOLD
Apollo21 is offline
post #3 of 5 Old 12-23-2009, 03:54 PM Thread Starter
Apollo21
the light also went off but it still spits the code
SOLD
Apollo21 is offline
post #4 of 5 Old 01-12-2013, 03:58 PM
miami5th
I know this is several years later but what was the outcome of this? My 2001 JGC limited is throwing the same P0158.
miami5th is offline
post #5 of 5 Old 01-12-2013, 10:57 PM Thread Starter
Apollo21
I've done plugs but i still get the code. I really think it is the sensor. It's probably shorted on itself.
SOLD
Apollo21 is offline
Engine Code help- Code 11 athomas08 ZJ Grand Cherokee Forum 3 05-07-2009 12:56 AM
Code Po 442 & 456 beckysjeep ZJ Grand Cherokee Forum 4 10-16-2007 07:19 AM
code 27 comes up teemsta ZJ Grand Cherokee Forum 3 07-02-2005 12:37 PM
Code 37 sixtires58 ZJ Grand Cherokee Forum 4 06-26-2005 03:23 PM
Code 27 TheUser ZJ Grand Cherokee Forum 3 06-16-2005 02:28 PM
