clink sound on front driver side wheel? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > clink sound on front driver side wheel?
SYE Kits from CCOR! 706-207-4140Stainless Steel Door Hinge PinsPoly Door Hinge Bushings
Unread 08-14-2014, 06:49 PM   #1
Durango323
My 02 wj makes this sound when I go over the smallest bumps, it sounds like 2 coins hitting eachother. Mostly on street bumps and un even roads. It also makes like rubbin sound on tires when I turn . Any idea what it might be ? I have 245/65/17s if it helps
Durango323 is offline   Reply With Quote
Unread 08-15-2014, 08:25 AM   #2
JohnnyV
Could be a combo of worn Tie Rod Ends and bad wheel bearing hubs. To check the TREs have someone move the steering wheel back and forth while you look underneath for odd/loose movement.
2002 WJ Limited 4.7L
1995 ZJ Laredo 4.0L
1989 XJ Laredo 4.0L - Sold
JohnnyV is offline   Reply With Quote
