climate control air flow problem - JeepForum.com
post #1 of 4 Old 10-14-2013, 08:42 PM Thread Starter
01jp
Hi everyone,
I got a 2001 jeep grand cherokee and the climate air flow won't switch from vent to floor. the air goes out only to the top which is the defroster even you put the switch to vent or floor. The blower is working fine it just the control wasn't.Can somebody give me a hint? Thanks in advance.
01jp is offline
post #2 of 4 Old 10-15-2013, 09:54 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to WJ Forum.
The forum you posted in (JeepForum Announcements & Comments) is for questions about the forum, help with using the forum, and help with software problems.
Welcome to the forum.
Wheelin98TJ is offline
post #3 of 4 Old 10-15-2013, 11:56 AM
hamilton5
vacuum leak
hamilton5 is offline
post #4 of 4 Old 10-15-2013, 09:25 PM
bgshemi
2003 WJ
Vacuum leak
2003 Grand Cherokee
Mine was doing the same. It was a bad vacuum hose to the cruise control box located under the battery box on the passenger side. Hope this helps.
bgshemi is offline
