Clicking noise when turning the steering wheel slightly back and forth - JeepForum.com
post #1 of 6 Old 11-23-2013, 07:53 PM Thread Starter
r1passedu
Wj Clicking noise when turning the steering wheel slightly back and forth
I'm getting a clicking noise when I move the steering wheel back and forth slightly. Also when I'm driving. I got under the truck and had someone move the steering wheel back and forth and noticed a little play in the tie rod on the passenger wheel the connects to the pitman arm. Can this be the problem or can it be something else. I checked the wheel bearings also for play. Everything else looks tight. I had recently replaced the lower control arm and ball joints.
r1passedu is offline
post #2 of 6 Old 11-24-2013, 08:06 AM
car5car
2002 M-38
I was fighting this problem yesterday. I found out, I had 2 clicks, one was in steering box, I adjusted it (nut and bolt), second inside, I still didn't find it.
Couple years ago I was diagnosing freeplays in my Durango, I found 4 problems, had to buy steering shaft.
I have read somewhere about spraying WD40 to eliminate inside shaft click in some truck, it was probably Ford.
01 XJ 2wd 4.0
car5car is offline
post #3 of 6 Old 11-24-2013, 09:57 AM
Upside
There's a TSB in the steering section depending on your model year.
http://www.wjjeeps.com/tsb.htm#1900103
Upside is offline
post #4 of 6 Old 11-24-2013, 03:53 PM Thread Starter
r1passedu
It sounds like it's coming from the steering shaft too nothing in the front end really. It doesn't shim or shake when I drive it. I'll check the steering box and wd40 the shaft tommorow. Where is that nut you tightened on the steering box??? Thanks!!
post #5 of 6 Old 11-24-2013, 03:59 PM
car5car
2002 M-38
It is on top, you'll see it, find the procedure, it is dangerous if done wrong. Nut is 5/8"
http://www.justanswer.com/gm/72r05-g...-s15-work.html
01 XJ 2wd 4.0
car5car is offline
post #6 of 6 Old 11-24-2013, 05:57 PM Thread Starter
r1passedu
Thank you I'll check it out.
